port polish etc etc
as i understand it a port job just enlarges the intake/exhaust valves. while the polish just maximises the increased airflow. what kind of effect would this have on a NA car? i know that this is common of cars with overbores and/or forced induction, but would it be an effective power adder in a NA application (ve30de). if it does add power, is it throughout the powerband or is it just in a few hundred (short) rpm? i've heard that bad port jobs can cause a loss in low end and screw up the drivability of your engine. nissan made a pretty good/efficient engine to start with so i wouldnt want to screw it up.
as shown to us by maximamike (i am not flaming you) there is a "nissan kit" avialable that includes rods/pistons/rings/ and a machined crank. how does machining the crank help to make power?
yes, i know some of you have beaten me to thwe punch: in making an all motor Maxima.
tia
tia
There's an excellent article on head mods in this month's SCC.
that thing will answer all your questions on a general level.
I don't really thing anyone has done much with the VE heads yet, so it's still kinda up for grabs as to whether it will help or not.
the VG ports look very small and could stand a lot of tuning.. but that's also partly where our low-end torque comes from.. I'll work on some stuff later, nothing planned for the near future.
From what I understand
porting and polishing helps the air flow faster through the intake and the exhaust manifolds. If you have a K&N or something of the sort, you'll get even more O2 through the engine more quickly and smoothly = more power! I think I'd do it if I weren't a broke a _ _ intern! How much does that cost anyway?
there were probably only be minimal gains untill you are running high boost or high compression. most NA cars will only see 1-2 hp by doing a port and polish. not worth your time or $$
tia
tia
porting on na engines will gain most power by shaping the ports to direct the air flow most efficiently. on na engines, if you port too much, you'll lose power. with a power adder, you want a big port.
also, you'll want to port match the manifolds to maximize power. a cam is also neccessary to take advantage of the increase efficiency.
if all port work is done correctly and the cams match well, you'll get at least 20hp to the wheels.
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
![Mad](https://maxima.org/forums/images/smilies/mad.gif)
Gains from P/P all depend on -->
1) How crappy the heads are before you work them. If they are already good, then not much can be gained. If the design is a piece of crap before, then of course more hp can be gained. But for your reference, Nissan design is fairly good.
2) How good the machist is. If he is an idiot, then you will probably LOSE power. It's much easier to LOSE power than it is to gain power.
For mild porting, stock cams are probably okay, wild P/P will probably require diff cams to take advantage of the work.
followthadollar
09-23-2015 08:31 PM
