Trunk not opening
Old Oct 22, 2004 | 09:07 PM
Loe max's Avatar
Trunk not opening
Well tonight, I started to play around that little lever in the trunk, now it no longer opens and the key will not turn the lock. Any idea's?
Old Oct 22, 2004 | 10:38 PM
twinkle's Avatar
yea, the key doesnt like to open my trunk...what you need to do it put the key in and jiggle it around and try and turn it, eventually you should get it. then when you open the trunk flip the lever back, and stop playing around with it, it locks out the power opener, so you have to have the key.
Old Oct 23, 2004 | 04:49 AM
Greeny's Avatar
¯\(°_o)/¯
Stop playing with your car.
Old Oct 23, 2004 | 06:36 AM
Loe max's Avatar
ya I need to stop playing with my car
Thanks twinkle, I'll try to jiggle the keyhole more
Old Oct 23, 2004 | 08:36 AM
Evil_Twin's Avatar
I did that, and my key was shot. (This was back when I didnt know that I could take out my seats.) Well the armrest hole lead to the trunk, there wasnt any backing on it, so me and my friend had to sit there trying to stick our hands and arms in to flip the lever. Yeah, it sucked...
Old Oct 23, 2004 | 10:23 AM
Loe max's Avatar
Looks like thats my only option right now since the lock is being stubborn.
Old Oct 23, 2004 | 01:24 PM
Ninty-two-se's Avatar
If you have the hole cut behind the armrest then you can use a stick to filp the lever instead of pulling the seat out or trying to stick your arm through(which might work if you have long enough arms)
Old Oct 23, 2004 | 03:07 PM
twinkle's Avatar
well, just pretend your car doesnt have a trunk from now on....also if you have any other sets of keys to the car, give them a try, but i really think jiggling it around will eventually work...
Old Oct 23, 2004 | 05:50 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
it takes 5 min to take the seat out.....
Old Oct 23, 2004 | 06:13 PM
internetautomar's Avatar
mod or sell?
At least I'm not the only one.
I pulled the back seat out, took one big **** pry bar to get the seat bottom out.
Old Oct 23, 2004 | 06:25 PM
bhunter's Avatar
Did the key USE to turn the lock?
Old Oct 23, 2004 | 08:18 PM
Q-$h@d0w's Avatar
not to jack the thread, but how come the orginal key the one with the black top and says nissan starts the car and opens the trunk but not the doors? Is this just me and my car??? I been wondering if it was common or not due to the keyless entry pad on the doors.
Old Oct 23, 2004 | 09:07 PM
mod or sell?
car came with 2 types of keys.
A valet key and a master key.
does the key work in the glovebox?
Old Oct 24, 2004 | 07:09 AM
Evil_Twin's Avatar
Hey internetautomart, this part confuses me too. I finally got the key cut to the code, and the key does work in the glove, but not in the trunk. And my alarm always goes off when I use the key to open the door.
Screaming - Best way if the key doesnt open the trunk, just take out the seats. Like what Maxima-4DSC said, it takes 5 mins. 5 clips, 4 screws and you're done.
Old Oct 24, 2004 | 07:21 AM
mod or sell?
sounds like what i've got.
I think that either:
A. lock cylinder is rusted tight (doubt it)
B. trunk was replaced but not the lock cylinder (more likely)
have you tried your key in the passenger door to disarm the alarm?
Old Oct 24, 2004 | 01:34 PM
twinkle's Avatar
try spraying some WD40 inside the trunk lock see if that helps it turn...do you know if there is any possibility that the ignition key was changed and the door and trunk ones weren't?
Old Oct 24, 2004 | 04:59 PM
Nick93SE's Avatar
lol this happened to me yesturday. We took out the seats, and the hole was pretty big so my friend just crawled right in and hit the switch. Dont play with that lever anymore lol.
Old Oct 24, 2004 | 08:13 PM
Loe max's Avatar
Those seat bottoms takes some man-power to remove but the trunk is now functional
Old Oct 24, 2004 | 08:22 PM
Nick93SE's Avatar
lol yes tehy were.
Old Oct 25, 2004 | 11:35 AM
KRMaxima21's Avatar
You probably have to flip that switch back down. It's for the valet lock so whenever you have your car valet parked they can't open your trunk with the key or by the trunk button but if you know the keyless entry code you can open it. Yeah definitely use a stick or a coat hanger and push the lever down then try it.
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
mrgooch
Sep 21, 2015 08:43 PM
