help with sunroof
Old Oct 27, 2004 | 09:09 AM
Jeff583's Avatar
help with sunroof
ok i need some help, started out one day my sunroof just stopped working so i didnt touch it for about a week. Then yesterday i started messing with it and so far i have checked the sunroof motor, harness, relays. I switched all of these with the parts out of my 89 gxe and the all were exactly the same but still nothing then i decided to go get the multimeter and test for power, and im not getting power up to the sunroof, but i am getting power to the two map lights, but they may be seperate power supplies, well if anyone has any ideas on were there maybe a fusible link or anything like that then i could use the help, the sooner the better cuz all of my upper interior is out of my car and it sux.
Old Oct 27, 2004 | 09:36 AM
«§»Craig B«§»'s Avatar
First thing to check is fuses, check the 6th one up from the bottom on the left hand side, it's 10A (check ones above it and below it too because I could be off one).
Old Oct 27, 2004 | 01:59 PM
Jeff583's Avatar
i already checked all the fuses in the fuse block none were blown, but you are just the one i wanted to ask if there are any wiring diagrams that you know about that include all the sunroof info
Old Oct 27, 2004 | 02:12 PM
I figured you probably did check the fuses, but wanted to ask to make sure
Test the switch also (continuity in each position). It uses a ground switch so you wont see any power on it.
Here's the schematic if it helps
http://craigbrace.homestead.com/file...ma/sunroof.pdf
M15 (the circuit breaker in the schematic) is located just behind and below the fuse box)
M2 (ignition relay) is located in the drivers kick panel
good luck
Old Oct 27, 2004 | 08:02 PM
Jeff583's Avatar
thanx ill have to check it out in the morning, that should solve the problem
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
Vequity
Sep 10, 2015 05:26 AM
