tranny filters!!
Old Apr 17, 2001 | 11:57 AM
wizard6161's Avatar
does our auto. trans, cars have a tranny filter? I am just asking cause I am about to flush mine and I want to do the while nine yards at once.
thank you
Old Apr 17, 2001 | 01:08 PM
brubenstein's Avatar
It has a wire mesh screen that is under the pan. The problem is that the trans is sort of up-side-down, and the pan is on the top. You can't get to it without pulling everything apart. Don't bother trying. It's the sort of thing that you would change if you already had the transmission put and apart.
Old Apr 17, 2001 | 01:10 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
thank you
yeah its inside the tranny and you don't have to change it...
just curious how you are doing a tranny flush yourself? do you mean just changing the fluid cause that's not a flush...
Old Apr 17, 2001 | 04:44 PM
wizard6161's Avatar
I am doing the drain and refill thing.......but I was also considering the other method...the one that you pull the hose the is going to the radiator and then fill in from the dipstick tube until the fluid comes out red from the hose. you think this will work?
Old Apr 17, 2001 | 05:13 PM
It works fine. Just make sure you pull the return line (closest to the drivers side), and do it 2 qts at a time.
Old Apr 18, 2001 | 08:48 AM
wizard6161's Avatar
the return line??
I thought I would have to pull the line that is going from the tranny to the radiator not the other way around? I maybe wrong but I just want to make sure I don't screw this up.
please correct me if I am wrong.
Thanks guys.
Old Apr 18, 2001 | 09:31 AM
Re: the return line??
Thanks guys.
There are two line that run between the transmission and the radiator. You want the return line so that the heat excahanger in the radiator is also flushed out.
Old Apr 18, 2001 | 09:35 AM
wizard6161's Avatar
got ya!!
I see what you mean now....thanks dude
Old Apr 18, 2001 | 05:36 PM
wizard6161's Avatar
one more thing!!
when the whole mess is performed..the engine should be running and the gear should be in "P" right ?
Old Apr 18, 2001 | 06:04 PM
Lj90Se's Avatar
Tranny flush
Hey Wizard do you think you can post a pic or email me with pics of you doing the flush ?
Old Apr 18, 2001 | 06:08 PM
wizard6161's Avatar
I will try
I will try to take some pictures when I do it depends if my cousin will let me use his *$1500* sony camera. he get's all paranoid and stuff when someone uses it espicially when I tell him it's gonna be around oil and stuff...lol good luck to me guys.
=) but I will do my best
Old Apr 18, 2001 | 06:27 PM
Lj90Se's Avatar
Good Luck 2 U
I would like to get this done also since i recently got my tranny rebuilt, the warranty just ran out and it's acting kind of funny.
my03maxima
Jul 28, 2024 07:40 AM
fx4five
Oct 18, 2015 06:57 PM
Justin Kroll
Oct 1, 2015 07:03 PM
fx4five
Oct 1, 2015 04:58 AM
