Ok this is really messed up..............
Old Apr 17, 2001 | 12:02 PM
Jon91SE's Avatar
Pusssseeeehhhh
So for the passed 3 days my car has been running like absolute crap, its bogging ,hesitating , idling ruff and its a big mess, accelerating was jumpy at best and it would sound like it was missfiring, it woudl shudder at highway speeds when coasting or accelerating at partial throttle , so all of this i finially decide to bring it to the shop......well of course its not doing a thing when the mechanic has it, now im trying to explain to them that it was so bad that my car practcially came to a stop on a local road and i almost had it towed it was so bad. So now its working fine and they cant fix anything unless they have a problem, what on earth could make such a severe problem vanish into thin air like that. i just had work on my O2 sensor wiring done, but other then that nothing has been touched....im really confused and worried......wahts going on? i just find it hard to belive that whatever it was is now gone and wont come back.....
Old Apr 17, 2001 | 12:19 PM
Chris Gregg's Avatar
Get Off My Lawn
Sometimes these cars are possessed!
My fog lights did that when I first bought the car. One light blew, a few days later the other would. Replace the bulbs, then the fuse would blow, replace it, another light, then the other light then the fuse would blow again. Replaced it all agian, then they wouldn't come on! I checked wiring, nothing! Took it to an electrical shop, they said it was probably a short "somewhere." Then one day they came on and I've not had a problem since, that was a year ago! Go figure! As far as what you've experienced, had you washed your engine or anything. Water in the distributor maybe or a crack?
Old Apr 17, 2001 | 12:23 PM
Jon91SE's Avatar
Pusssseeeehhhh
Re: Sometimes these cars are possessed!
i havent washed anything, my car is filthy right now it needs to be washed but if only you could have sat in the car and seen/felt how messed up it was and now its like gone....its almost creepy
Old Apr 17, 2001 | 01:11 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i have had the same exact symptoms before...it was there then it vanishes...there and vanishes...i attributed it to maybe bad gas or water in the gas but 2 weeks ago it came back for an hour and then vanished again...no idea what the problem is or was....if you find out lemme know cause im pretty damn curious
Old Apr 17, 2001 | 01:39 PM
newmaxguy's Avatar
dirt in the fuel line.
Old Apr 17, 2001 | 02:16 PM
eric93SE's Avatar
Fuel filter, possibly a sticking EGR valve.
You should bring it in for diagnostics at a nissan dealership they are the only ones who can do proper diagnostics with the consult tool.
could also be an injector, have you had any work done on the injectors? A power balance test will show right away if any are bad.
Old Apr 17, 2001 | 03:57 PM
KraZel
I had that problem with the car straight shutting completley off while i was driving all the time. Brought it to the mechanic and it ran fine. The problem was my positive battery wire it keep slippin and movin cause my car to stutter and stall
Old Apr 17, 2001 | 10:37 PM
shi89max's Avatar
mine does the same thing
my max does the same exact thing, and i cant figure what the hell is wrong with it, i took it to the machanic too, and of course the same thing happened to me, it worked fine for the machanic. its been doing this to me off and on for a while one day its fine the next day its like this. what should i do?
Old Apr 17, 2001 | 10:50 PM
Jon Little's Avatar
mine did the same thing but i went to just shell gas and the promblem stoped
Old Apr 17, 2001 | 11:08 PM
Jon91SE's Avatar
Pusssseeeehhhh
OK guys i think i have narrowed it down and tomorrow im going to have my mechanic look at this, see i noticed that my fans started blowing even when i would start the car cold...well my brother used to work on nissans and this was a common problem, the head temp. sensor is bad and its messing the car up and it thinks its hot when its not etc.... ill tell you what happenes tomorrow but im pretty sure that is what it is
Old Apr 18, 2001 | 01:22 AM
Brad's Avatar
True... True...
Mine has done that for about 6 months, thought my ignition system was mmessed up turns out my TORQUE CONVERTER is locking up but there is a seperate part ot the computer that tells the transmission what to do and dude at the dealership said it would be logical to buy a $300 computer part before a $1500 tranny rebuild. Anyway I found out my mystery so good luck on yours.
Old Apr 18, 2001 | 10:44 PM
Jon91SE's Avatar
Pusssseeeehhhh
Well thats definatly what it was, the head temp sensor and the harness attached to it, the harness was rusted out and the sensor was bad. parts and labor $150 not too bad and its running like it should
Old Apr 19, 2001 | 10:14 AM
shi89max's Avatar
hope its that
wow finally a solution to my problem that i have had for 2 monthes now, where did you go to have it fixed a regular machanic or nissan place?
Old Apr 19, 2001 | 10:57 AM
Jon91SE's Avatar
Pusssseeeehhhh
i just went to a local shop by me, i dont think its any major problem to fix, but from what i hear its common
Old Apr 19, 2001 | 02:34 PM
KraZel
thats a close one
I'm glad it turned out to be a minor problem...dont u get tires of these repairs
Old Apr 19, 2001 | 04:12 PM
eric93SE's Avatar
When I got my max, one thing I did was check/clean all conectors and grounds. Its an old car now and its just apart of maintaining it.
Old Apr 19, 2001 | 06:56 PM
Dirksmoothe's Avatar
COOL!!
okay, I am glad that it is not my own car that is possessed. I will have to take it down and see what is up. Thanks for the info, and being a guinea pig for the rest of us.
litch
123
Jan 4, 2024 07:01 PM
wyobbagy
Jan 3, 2023 12:03 PM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
Colossus
Sep 9, 2015 05:46 AM
