Timing belt
Old Dec 4, 2004 | 07:34 AM
fabio's Avatar
Timing belt
Hi Everyone, please can someone tell me...Today while driving my Maxima it is a 300E 1992 model my timing belt tensioner came loose and dropped under the car, I was pulling off, have I bent my valves or does this car have a protector when this happens...PLEASE HELP TO LET ME KNOW
Old Dec 4, 2004 | 08:26 AM
DanNY's Avatar
Ad·min·is·tra·tor
most likely you have a door stop as a motor....AKA yes it's a good chance your valves are bent along w/ other stuff.
Old Dec 4, 2004 | 08:51 AM
Matt93SE's Avatar
STFU n00b!
yup.. if the timing belt came off or broke while the engine was running, I'm 99.9% sure your valves are gone.
I have an engine in the garage that snapped a belt on the highway and EVERY SINGLE valve is visibly bent, and there are dents in every piston.
Old Dec 4, 2004 | 09:23 AM
coreyblade's Avatar
how hard is it to change the timing belt in a max? also what all do u have to do?
Old Dec 4, 2004 | 10:05 AM
Scope's Avatar
Im izz sexay
You have to get a new engine to be on the cheap side. Changing the t-belt after it snapped won't fix the valves and pistons You need a complete engine rebuild which IMO will be a waste of money (unless you did some serious internal work that needs to be revived) if you can find the same engine for 300-400 at a local junkyard.
Old Dec 4, 2004 | 10:17 AM
DanNY's Avatar
Ad·min·is·tra·tor
depends on your skills. i can do it...but others may have a problem...know what i mean. it's not rocket science...but if you do mess up you can say good bye to your motor...wanna risk it?
Old Dec 4, 2004 | 11:44 AM
fabio's Avatar
Timing belt tensioner
My timing belt tensioner went not the timing belt having snapped, only when I pulled off
What do you think......maybe I haven't bent valves
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Ray229Harris
Sep 16, 2015 08:16 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
