how to install pacesetter header
Old Dec 5, 2004 | 06:15 PM
prcjazzz's Avatar
Need help!!! How do i install pacesetter headers?
Old Dec 5, 2004 | 06:19 PM
prcjazzz's Avatar
how do i fit them together?
Old Dec 5, 2004 | 06:39 PM
goon9's Avatar
Someone once called those pacestetters "Aids to a car"
From what i heard they shake the crap outta your car. Busting manifolds studs, etc.
Old Dec 5, 2004 | 06:46 PM
prcjazzz's Avatar
i know,i hear alot of bad things about them,i just got them for the mean time in between time.im going to get better ones. i just dont understand how to fit the pipes together,or how to match up the bolts.i mean,what are the springs for????
do a use a mallet and knock the pipes together?
Old Dec 5, 2004 | 07:29 PM
ChrisCheezer's Avatar
-you should of asked about thoes things before you baught 'em.
send them back asap. no joke!
thoes things arent worth the time or money, they have fitment problems, the finnish will burn off in 5 min (for real), power gain is very very little if nothing,flanges are super thin, pipes/welds erode quickly,some spend close to 1k to fix broken studs, prepare to spend more! ?!?springs?!?! sounds like some cheap way of making a "flex section" in the pipe
Old Dec 6, 2004 | 06:59 AM
dantegl's Avatar
haha its not that hard, i just did mine last week, the springs go on the front headers, and no u dont knock them with a mallot, they have that ball joint design to allow for engine flex, 3 springs in the front and two of them connect at the end of the next pipe that connects of the front one. now there are two probs that u might run in to: 1. the bolts might be too long, in my case they were and i ended up going to the parts store and buying some new one. 2. my 02 sensore wouldnt fit the new housing on the pace setter headers, i just put two tack welds to hold it now for now (seems okay) and i have to get this thread repair thingy to weld in the hole so the 02 sensor will screw in, i hope this helps you
Old Dec 6, 2004 | 02:26 PM
goon9's Avatar
Those who take advice are wise, the ones that don't just aren't.
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
Maxboy23
Sep 4, 2015 06:04 PM
Johnny9595
Sep 3, 2015 05:18 AM
