Spindle Replacement
Old Dec 10, 2004 | 03:54 PM
usaf_hydro's Avatar
Spindle Replacement
I've been going through wheel bearing quite often and I think the spindle is screwed. Is there any place that just sells the spindle or do I have to purchase the whole axle ( Front Right )?
Old Dec 11, 2004 | 06:10 AM
usaf_hydro's Avatar
anyone have inputs???
Old Dec 11, 2004 | 07:33 AM
Matt93SE's Avatar
STFU n00b!
umm, did you ever replace the wheel hub while you were changing the bearing? often the hub goes bad and takes the wheel bearing out with it. if you just replace the bearing, then you don't get anywhere...
you can pick up used spindles at a junkyard for about $50 a side and just swap them into your car. make sure you get one off a 92-94 SE model though- the axles are different diameters on the VG cars.
Old Dec 11, 2004 | 09:54 AM
usaf_hydro's Avatar
when i first got the car, the person selling to me said they thought the tie rod was going...until I got it up on the rack and checked everything out my right wheel had ALOT of free play in it. So I changed the bearing not even thinking about anything else..."dumbass"! so when that one went bad after about 3 months I figured I just changed it incorrectly, but how hard is it to screw up changing one right? So changing the whole package (hub/spindle/bearing) should solve the problem?
Old Dec 11, 2004 | 10:09 AM
used parts's Avatar
Torque
Just make sure you torque everything down to spec.
Old Dec 11, 2004 | 12:48 PM
acidspit86's Avatar
if it is a back wheel bearing your supposed to snug it down, back it off then tighten to 5lb/ft (as tight as you can get it with your fingers, maybe a little more) if your getting them too tight, youll be going through them weekly...
edit: drive wheel bearings, (front) need to be tightened to 200lb/ft or more
Old Dec 11, 2004 | 04:45 PM
usaf_hydro's Avatar
its my right front....I torqued everything down to spec....being an aircraft mechanic I know the importance of everything being done right
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
