Why is flushing the coolant system bad?
Old Dec 22, 2004 | 07:38 AM
DGruber 58's Avatar
I was reading
http://forums.maxima.org/showthread.php?t=363360
and someone said he shouldn't have even flushed the system. Why?
thanks for your replies
Old Dec 22, 2004 | 07:57 AM
DanNY's Avatar
Ad·min·is·tra·tor
if you neglected your coolant system...flushing it might pull some of the deposits off the walls of the coolant passages. those deposits might have been sitting around and it might've sealed a leak.
it's pretty much the same arguement as flushing the tranny.
in both cases the engine/tranny would've needed the work done regardless the flush done to it...it's just a matter of time.
Old Dec 22, 2004 | 08:00 AM
bhunter's Avatar
I for one disagree with them. Flushing gets the sludge out that clogs the system. First thing to go on a car that never gets flushed is the heater core. There may be times when a flush made a pending problem show itself, but neglect was the problem, not the flush.
Old Dec 22, 2004 | 08:10 AM
DanNY's Avatar
Ad·min·is·tra·tor
them?
i'm siding with you here.
Old Dec 22, 2004 | 09:33 AM
bhunter's Avatar
DanNY, I wasn't disagreeing with you, but the ones in the thread he noted. I was typing my reply the same time you were.
Old Dec 22, 2004 | 09:42 AM
PulsarDriver's Avatar
I didn't really want to flush mine, but I didn't have much choice. My rad and core were both full of rust Seems sorta odd, since the radiator isn't that old. I know the core is old as **** though.
Everything seems okay though
Old Dec 22, 2004 | 10:23 AM
Wiking's Avatar
Better not ever look up in the sky. Might fall on ya.
Never make, clean, correct any-body/thing = no errors? ...?
Happiness depends on what happens. Make happen - [decide to] be happy when happens.
Where does that [decisiveness] come from?
Old Dec 22, 2004 | 04:35 PM
bvtran's Avatar
94c Big Max
hah. I'd flush the coolant regardless (NOT the tranny) cuz I wanted maximum cooling.
Old Dec 22, 2004 | 04:59 PM
eric93SE's Avatar
The problem is that many org members are not first owners. running flush solution can remove anything a previous owner put in the coolant as an easy fix. I'm totally for drain/fill for the cooling system. Personally I switched over to the red stuff a couple years ago, and recently did a drain/fill when I did the vtc rebuild. Now if you have major problems like rust (a neglected system ) then sure flush away, and replace all the hoses as well. I replaced ALL my coolant hoses a while back, there was nothing wrong with ANY of them, I'm just a maintance freak and figured well 100k miles sounds like a good time to do them.
Old Dec 22, 2004 | 05:06 PM
DGruber 58's Avatar
hey thanks for all the input. I was planning on flushing the system since I have the car apart anyway (damn manifold studs...).
Old Dec 23, 2004 | 12:24 PM
longpole938's Avatar
flushing the system isnt back.... back flushing the system is what is harmful.
sctludwig
Sep 1, 2022 01:32 PM
DJLAX152
May 4, 2021 11:46 AM
captchaos
Mar 15, 2016 12:18 PM
Violator
Sep 9, 2015 10:14 AM
