Quick/Cheap Fix for VTC Problem
Let me go ahead and say that I am in no way a mechanic and just had a brainstorm that I would like some feedback on. As far as I understand it, the VTC ticking noise is caused by a lack of oil or lubrication to the cams (or a part of them). I was wondering if some of those "super-lubes" would help since they claim to thoroughly lubricate every part of your engine. I know that Z-Max is a fraud since I tried it in my previous car two times (89 Accord) and it made no appreciable difference other than the $40.00 per usage drain on my wallet. But what about "Motor-Up" or "Dura-Lube"? My VTC tick isn't horrible now, but it is random and embarassing, so I would like to know what I could about it other than spend over $1000.00 for new cams.
hmm, i don't know about all that....
I haven't gotten the TICK yet on my 93 SE, and I have 102k on it.. but, some members with VE Maxima's on the org have Grounded their VTCs to get rid of the ticking noise.. It's a cheap fix and doesn't cost you anything, however it will not fix them though, just shut them up.... Search for "Grounding VTCs" or something of that sort, you'll probably find soemthing useful.
I read through some of the posts on grounding the VTC and in the long run it may do more harm than good. I already feel that my car lacks adequate low-end torque (having that checked tomorrow) so I certainly don't want to do anything that would underpower it more. I may just have to cash out some bonds next month and have the darn VTCs replaced. Any idea how much? Also, I heard rumors that there was a recall/bulletin about this. While I know that it is highly unlikely that Nissan will do it for free on a nine year old car, but it would be nice to have a bargaining chip.
I have a 93se auto, when I first got my car she ticked when cold (during winter) but now that Ive been changing the oil/filter regularly its almost totally gone.
But I did get the technical service bullitens from alldatadiy.com and they say that they dont have to be fixed and it wont cause any damage. They show that its a spring thats faulty in the timming sprokets, but that the whole assembleys can also be replaced. So the parts for the rebulit arent expensive its the labor that gets ya.
I think grounding the VTC's is ****ing crazy, I wouldnt want to loose my second torque peak, aaaaahhhhhhhhhh
If anyone with the vtc problem that would be interested in checking out the bulliten I could probaly fax it.
I would deffinitely be interested in taking a look at that bulletin. I'll check and see if I can get access to a fax machine tomorrow. Is it possible to just replace the sprockets and not pop for two new cams?
Some info
Your VTCs have no influence whatsoever on lowend. They don't even engage untill over 3200 rpm. That's well after most people shift during normal driving. You won't hurt anything by grounding them either. All that does is keep the cams from rotating a few degrees to allow better high end breating. So you'll lose a little power in the part of the band that you harldy ever use anyway.
I seriously doubt it will do anything like that. I know on my car, it was short on low-end due to the VTC and the rewire did nothing to make it worse, better if anything.
It takes all of 5 minutes and may cost you $5-10 at the very most. If you do notice a loss of power or anything else for that matter, just undo the mod which woulnd't take more than a minute
Just an idea, if you dont want to try it, that's cool too.
Craig...
Is there anyway to get those pics working on your site again? I have alot of driving to do this weekend and I was gonna do the rewire. I can prolly do it w/o but my mind would be more atease with the pics
Or even if there's a mirror to your site somewhere...
Re: Craig...
http://www.geocities.com/bracecraig/maxima/vtc/
you may have to hit refresh a few times to get it to load, but it should work
also, some of the pics are really crappy quality so when I put them on the webpage, they are about 50-75% normal size so you may want to open them in paint or something so you can adjust the zoom and better see the picture
Mar 12, 2020 12:06 AM
