Help lights are going crazy!!
I just got my fuel injectors changed this morning and this evening I put on my head lights, and they go on but my instrument lights dont nor do the climate pannel lights nor do the tail lights. then I discover when I press the brake pedal the instrument lights, and climate lights and tail lights go on. I checked the fuse and they work. even when the car is off I press the brake light and the instrument lights go on.
I have a 90 Maxima SE does anyone know whats wrong with this?
Main light sw contacts are worn, burned. Take the assy out, open, clean contacts, helps for a while.
If not, Check the fuses again. RH parks are connected with instru.
Theres short circuit to brake light circuit.
See the forum...
http://forums.maxima.org/showthread.php?t=366134
I just changed the stop light fuse because it burned out when I tested it with the fuse tester and the lights now go on when I turn the switch on but the lights also still go on when I press the brake pedal. Ar you sure it has nothing to do with a harness the mechanic forgot to out on or is loose some where under the hood.
Wire color into sw =R/Y
Wire color rear ligts =R/G
Rear has combination lights: If water or smtg bent/shorted there, +12V will be routed to rear/instrument lights.
Wiring diagram can be found from the manual:
Maintenance Manual Online:
http://www1.autozone.com/servlet/Ui...&Parameters=004
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
