Starting problem maybe transmission??
Old Jan 7, 2005 | 05:45 PM
Josh's Avatar
Recently i have noticed that my car some times does not start right away, inorder to get it to start i put shifter into to the #1 position and then move it back to Park and then it will start. i think that the computer thinks it is in gear because all of my accessories come on and i can't hear the injectors clicking. has any one had this happen to them, is there a fix for a sensor or something?
thanks, josh
Old Jan 8, 2005 | 05:01 PM
internetautomar's Avatar
mod or sell?
your neutral safety switch is possibly misaligned.
try starting the car in neutral or pushing the shifter forward when you're trying to start
Old Jan 8, 2005 | 05:22 PM
eric93SE's Avatar
It's definitly your shift cable bushings. there is one at both ends of the shift cable. One is located above the cat. converter heat shield, and the other is where the cable meets the tranny. Replace both.
Interautomart is a post *****
Old Jan 8, 2005 | 05:53 PM
mod or sell?
Nope, I just always have an answer.
not neccesaarily the right one though
Old Jan 8, 2005 | 06:04 PM
eric93SE's Avatar
Indeed..........
Old Jan 8, 2005 | 06:08 PM
Josh's Avatar
thanks, will doing this permanatly fix the problem or should i buy a new neutral safety switch?
Old Jan 8, 2005 | 07:06 PM
eric93SE's Avatar
Like I said, its the nylon bushing, they brake and can fall off the car. Its not the switch.
See interautomart, misinformation>confusion>caos>GeorgeWBush......... .....
Old Jan 8, 2005 | 08:12 PM
ozzombie13's Avatar
I will eat your children
mine does it to sometimes and i just hit forward on the shifter and it starts. its second nature to just do it when i get in the car
Lakersallday24
Nov 7, 2024 07:31 PM
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
homeyclaus
Sep 3, 2015 06:15 PM
Gsantos79
Aug 8, 2015 07:41 AM
