'92 Maxima fuel injectors...
Old Jan 12, 2005 | 09:26 PM
slowmo's Avatar
1) I have asked a couple people before (mechanic and dealership) what is the difference between the different injectors used for Maxima. Everywhere I go it lists different color dot injectors. What is up with this?
2) How do I know which color injector dots I have without removing the injectors? I would like to order the injectors online and I don't want too much down time since this is my daily driver.
3) Are the injectors interchangeable or are they different?
4)For anyone that has changed the injectors themselves how much time did it take you? I am estimating that I could do it on a day off.
Sorry for so many questions. I hope they aren't repetitive.
By the way my car is a 92 Maxima GXE automatic with a vg30e. I have 2 injectors that aren't working (ouch!).
Old Jan 12, 2005 | 11:55 PM
Wiking's Avatar
Originally Posted by slowmo
1)... 5. I have 2 injectors that aren't working (ouch!).
2,3,4 -I suppose detailed answers can be found in the stickies?
5 -Whats the symptom? No click?
Old Jan 13, 2005 | 05:19 AM
internetautomar's Avatar
mod or sell?
resistance is the difference
when you pull the harness the dot is on the connector part of the injector
bosch has supperseeded both the black and the blue dot to one part number, but I don't remember if the blue replaces the black or the black replaces the blue
there's a writeup in the stickies on doing them I believe
Whatever you do don't buy rebuilts, they have a very high failure rate.
I sell the injectors at a very competitive price.
Old Jan 13, 2005 | 05:35 AM
Wiking's Avatar
- overseas also? visa?
- I have some unprintable words for bosch products overall [plugs]. The injectors are ok, I suppose... Are there other options?
Old Jan 13, 2005 | 07:03 AM
mod or sell?
I'll ship overseas too,
Bosch is actually based here in illinois for their North american division.
but you first posting does ring true (prior to editing).
nobody else makes the injectors. only bosch actually MANUFACTURES them.
Old Jan 13, 2005 | 07:50 AM
Wiking's Avatar
...only bosch actually MANUFACTURES them.
Edited THE bosch -feelings off. Not really necessary... Many times feelings rush before wisdom.
Are the originals also made by Bosch? Cannot imagine nissan making 'em...
Old Jan 13, 2005 | 08:27 AM
mod or sell?
yup, the originals were made by bosch too.
Old Jan 13, 2005 | 09:21 AM
rrrfoma's Avatar
I have a question too ... What gaskets are required when doing rail with injectors re-placement?
I want to order 'em b4 to start
Old Jan 13, 2005 | 09:49 AM
mod or sell?
upper plenum should be all that's needed.
Old Jan 13, 2005 | 09:56 AM
Wiking's Avatar
Ro verII
I was a kid and papa got a real car, that was sixties. Rover A60 model -52. One could drive 50km before it died. Repair: open trunk, hit the fuelpump there with a screwdriver and get next 50km's...
Then came the better Rover A75 model. It had a switch on the dash. When u car died, just flip the switch, off u go. That was the Rover design team solution: 2nd fuelpump kicked in...
Happened to read a car magazine 1999, Rover test drive: Interesting note - car died, had to be taken to service station...
Reason: fuelpump.
Will they ever learn? When u read Rover testdrives, look carefully... Btw. Hopefully no more Rover design teamers work for nasa.
As a kid i had mini. Now I've Got MAXI.
Old Jan 13, 2005 | 03:58 PM
slowmo's Avatar
Thanks guys. I didn't find anything I was looking for in the stickies. I also couldn't get a straight answer from anyone around here.
I haven't actually diagnosed the injectors persay. I am new to this fuel injection thing. The car was running rough and I checked each cylinder for spark. They all passed. I then checked each cylinder by unplugging one spark plug lead at a time and cylinders 1 and 2 are both dead. They didn't affect the idle at all. Since it wasn't spark--it was the injectors. I tried running an injector cleaner through them and it worked on one for a little while and then it was back to running rough again. The power is gone also. I bet I have the only 4 cylinder maxima ever!
Old Jan 13, 2005 | 04:04 PM
mod or sell?
Hardly, I had a 3 cylinder Maxima
Old Jan 14, 2005 | 01:26 AM
Wiking's Avatar
"I also couldn't get a straight answer from anyone around here."
- But the info floats aroun there. Have not changed injectors, will -not- comb through now, still seen it some where there here. No real problem, just dig in.
My direct question is still on: 5 -Whats the symptom? No click?
"I also couldn't get a straight answer from *** around ***."
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
Max Nu-BE
Aug 11, 2015 06:34 PM
maxima297
Aug 3, 2015 12:50 PM
