need some help fixing my friend's car...tech guys help me out.
Old Jan 17, 2005 | 11:23 PM
Can't Catch Me's Avatar
Car:
1993 Nissan Quest
180K Miles
3.0 V6
Problem:
After the engine warms up, it won't rev past around 2000-2500 rpm. The car will jerk and sputter at that point and will only return to normal after the car has been shut off and cooled down.
Help me out, guys. I'm hoping you guys in here will know since it's a Nissan of the same era as your guys' Maximas.
Old Jan 18, 2005 | 12:51 AM
Jeff92se's Avatar
I'm needing a caw
maf failure.
Old Jan 18, 2005 | 01:10 AM
Wiking's Avatar
Originally Posted by Can't Catch Me
Car:
1993 Nissan Quest
180K Miles
3.0 V6
Problem:
Maxima ECU uses MAF, TPS, Tachometer to ctrl the engine during six minute warmup. If one of those sensors fail, ECU drops to 2000rpm limit safe mode (not in your case).
After warmup period, O2 (&temp) sensor is added to the ctrl loop. If one fails, ECU drops to 2000rpm limit safe mode ... your case.
My guess would be O2 sensor or Temp sensor?
Old Jan 18, 2005 | 09:18 AM
Maxzilla91's Avatar
don't guess around, check ECU. if it's tripping safe mode every time and not intermittently the ECU prolly knows what's wrong.
Old Jan 18, 2005 | 09:23 AM
Wiking's Avatar
ECU=lottery machine with 50 answerss to 5000 problems...
Old Jan 18, 2005 | 10:23 AM
eric93SE's Avatar
WTF, c'mon dude don't disrespect the forum "Nissan Quest"
Car:
1993 Nissan Quest
180K Miles
3.0 V6
Like Jeff said its most probably the MAFS.
Old Jan 18, 2005 | 12:05 PM
subs1000w's Avatar
maf is the only sensor that when it fails limits to 2500rpms
Old Jan 19, 2005 | 12:23 AM
is there any way to know if the MAF on there currently is definitely bad? any way to test it? clean it? also, where exactly is it? i haven't seen my friend's car in a while so i just want to know exactly where to look. i'm guessing somewhere along the intake tube/throttle body area?
any other suggestions? thanks so much, guys.
Old Jan 19, 2005 | 01:52 AM
Wiking's Avatar
I have collected the sensor tst -how to- list on my web page. Link has been available, will u read?:
http://www.cardomain.com/memberpage/748507/9
Use it with the crap online manual, available via autozone.com
subs1000w --->"maf is the only sensor that when it fails limits to 2500rpms"
Not so. And that is Easy to tst...
Old Jan 19, 2005 | 06:09 AM
internetautomar's Avatar
mod or sell?
disconnect the maf and see if the symptoms change
Old Jan 19, 2005 | 05:20 PM
car's max rpm varies between 2000-3000 ish. does that mean it's not the MAF? the MAF problem exists when the max RPM is 2200 rpm, correct?
so if it's not a MAF malfunction, what could it be?
Old Jan 19, 2005 | 05:35 PM
sara92max's Avatar
When you disconnect the MAF, the engine will not rev higher than 2200 RPM.
So, if you cant rev the engine past 2200 RPM with the MAP connected, you probably have a bad MAF......I would also check the resistance of it also..
Click on internetautopar SAE logo for prices of a new or reman MAF
Old Jan 19, 2005 | 05:55 PM
mod or sell?
remember guys this a quest not a maxima, so it's limp home mode may be different than ours.
I stick by my suggestion to unplug the maf and see if the symptoms change.
Old Jan 20, 2005 | 12:48 AM
Wiking's Avatar
Quite a lot variables there. U have to eliminate one by one via checking...
Fuel: pressure, ignition: transistor/capacitor (if cap, replace with wires, plugs), all air flow variables: from filter to loose TB flaps, sensors: all 'ten' from tacho to O2.
--->Go find FSmanual. Inspect those probabilities mentioned in this chain. Then come back and tell about u results....
Ray229Harris
Sep 16, 2015 08:16 PM
maxipower
Aug 21, 2015 11:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
carlosvq30
Aug 17, 2015 11:32 AM
kirkhilles
Aug 8, 2015 10:53 AM
