Need electronic starter system diagram
Old Jan 26, 2005 | 05:38 PM
SoMarvelus's Avatar
Does anyone know where i can find or have a picture or pdf of the starter system diagram? like what wire is what and were it goes for a 1990 gxe. is it in the repair manual? i dont know if i wanna buy that yet. my problem is that i cant get enough volts from the battery to be able to start my car, so what my father-in-law and i did today was he made it so that i have to go under the car tap some wire to something to make the car start(and a little after that he made the connection close to the battery and tap the wire to the positive connector) while the key is turned all the way. so he said to try and get the diagram to be able see what goes where and which fuse and bla.h blah blah blah...i'm learning alot though
Old Jan 26, 2005 | 06:48 PM
Governor's Avatar
ur solenoid i the starter is shot..replace the starter
Old Jan 26, 2005 | 06:53 PM
Governor's Avatar
could also be ur neutral switch if you have an auto tranny...I'm betting on the sloenoid on starter..that is waht ur father in law had you jump accross under the car.
Old Jan 27, 2005 | 06:33 AM
SoMarvelus's Avatar
Its a 5spd, do you know where i can get the diagrams for him so that we can fix the wire so that we can start it w/o doing all that
Old Jan 27, 2005 | 06:12 PM
Governor's Avatar
do you see a broken wire??? If you can jump across the solenoid and start the car it is bad!! Replace your solenoid.
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
