Where is the thermostat?
Old Feb 2, 2005 | 01:02 PM
Winds50's Avatar
Ok, I'm not very mechanicly inclined but I know I can change the thermostat once i find the dang thing? Where is it?
1991 Nissan Maxima SE
Thanks,
Matt
Old Feb 2, 2005 | 01:04 PM
Jeff92se's Avatar
I'm needing a caw
http://www1.autozone.com/servlet/UiB...Parameters=004
Old Feb 2, 2005 | 01:07 PM
Winds50's Avatar
Thanks a lot!
mtnbikeair's Avatar
Okay heres the steps you want to follow...
1. Disconnect the negative battery cable from battery
2. Drain the cooling system
3. Then follow the upper radiator hose to the timing belt end of the engine to locate the thermostat housing. Loosen the hose clamp and detatch the hose from its fitting.
4. Remove the bolts and detach the housing cover ( you may need to tap it with a hammer to loosen it)
Then slap in a new one
Old Feb 2, 2005 | 01:08 PM
Winds50's Avatar
Actually... nothing for the maxima is availible on that site
Old Feb 2, 2005 | 01:09 PM
Winds50's Avatar
THANKS I think I found it!
mtnbikeair's Avatar
If you go buy the Haynes Maxima repair manual it has the steps i listed, but it also shows pictures, which always helps me.
Old Feb 2, 2005 | 01:31 PM
Winds50's Avatar
Yeah... i gave up... im dumb or somthing but I can not find the thermostat. My brother is gonna do it for me tomorrow. Thanks anyways guys.
Matt
Old Feb 4, 2005 | 09:41 PM
Pyrophilus's Avatar
I wanted to do this, and got as much as #3, but I cannot seem to be able to reach the bolts. the timing belt cover seems to be in the way and between strut tower and timing belt cover there is such a little room...
Is there something that I can do (besides removing the timing belt cover, which I don't even think will help) to do this?
Old Feb 4, 2005 | 10:50 PM
aminus21's Avatar
there are 3 bolts, 12mm i think. You can use a regular 3/8 inch ratchet, with a 12mm deep socket, to open them. And when you install the new thermostat make sure than the bubble thingy is facing up.
Miket2006
Mar 1, 2021 03:55 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
aminus21
Sep 12, 2015 04:53 PM
