Finally foundout what is clicking under dash
Old Feb 4, 2005 | 09:10 PM
Pyrophilus's Avatar
Hi,
This is an update on the previous post.
I have a '92 Maxima GXE with ACC that was clicking behind the glovebox when the ignition key was set to "acc" or to "on" (regardless of the engine being on or the climate control being on).
Some folks said that it might be blower motor, but tonight I finally took apart the area and located the source of the sound.
It is a little black box next to the blower housing. The blower motor is removed in the picture (excuse me for labeling stupid things like the Fan speed amp and blower motor housing, but wanted to make sure everyone knew the orientation).
The little black cylinder seems to be the source of the "tap, tap, tap, tap..." sound. The cylinder seems like a motor, and it is connected behind to a metal rod. I am wondering if this is the "intake door motor"? I think the motor is okay, it seems that the white plastic that the rod is connected to is completely seized. Maybe the plastic gears in the motor are slipping because the door is stuck?
By the way, did I identify this correctly?
Can anyone tell me the function of this little black thing? For now, I have left the wiring harness unplugged. I am guessing that this has to do with the "recirculation button"? After thinking this, I realize that at least for the automatic climate control, I can press the "recirc" button and it will light up even though the climate control is "off" (or even if fan speed is zero (as in cold engine)).
Anyway, does anyone know how I can get to that thing? The big metal bar is right infront and the blower housing is sitting below it. Do I have to remove the blower housing and the cooling unit (that the fan cont amp is plugged into)? I would rather not touch with anything that deals with AC.
Anyway, any help would be appreciated. Also, is there any detrimental effect of leaving this wiring harness unplugged (my guess is that I now do not have ability to "recirculate" interior air)?
Thank you for any help,
Old Feb 4, 2005 | 09:23 PM
«§»Craig B«§»'s Avatar
yes, that is the intake door motor
dont know why it's stuck though
cant really tell you much more about it though
Old Feb 5, 2005 | 08:22 AM
maximapitko's Avatar
The Bulgarian Guy
that's a great pic. If somebody can show me what I should change in there in order to make my fan speed work again will be great(now it works only on "4"). Thank you in advance!
Old Feb 5, 2005 | 09:14 AM
jwmaxse's Avatar
If your fan only works on "4" then your "blower motor resistor" is going bad. I've never personally seen one so I don't know what that part is, but a few of my friends had the same problem and that's what it was. Let us know what happens
Old Feb 5, 2005 | 09:30 AM
yup, definitely the problem
on auto units, it's called fan control amp but does the same thing basically
pics on my ACC swap page
no more whoring up pyrophilus' thread
Old Feb 5, 2005 | 11:34 AM
DennisMik's Avatar
I have the auto climate control and have the "only # 4 speed" problem. Thanks for the info.
Old Feb 5, 2005 | 12:30 PM
Pyrophilus's Avatar
It's labeled "Fan control Amp" in the picture. I changed mine 2 weeks ago. It was only working on 4th setting before I changed this. It's the "metal" part that the harness is plugged into.
Old Feb 5, 2005 | 02:20 PM
MaximamixaM's Avatar
I have a '94 gxe with electronic automatic climate control. Previously speeds 1-3 stopped working, and I didn't fix it, just lived with only high speed (#4). Now, even that has stopped working, so I have no fan at all, just whatever circulation is provided by driving at highway speeds. Sounds like I need a fan control amp. What controls speed number four (high speed) on the electronic climate control?
Old Feb 5, 2005 | 03:03 PM
jwmaxse's Avatar
The amp controls all speeds, but as it wears out I think you lose the first three speeds and, as you have found out, the last speed.
Pyrophilus...sorry I still don't know what that thing is.
Old Feb 5, 2005 | 04:41 PM
Pyrophilus's Avatar
How I learned to change my fan control amp...
Everyone whose fan only works in #4 speed (or has stopped working completely after only working on #4), follow the directions in the photo to remove your fan control amp. Replace with new one and reverse directions to re-install it. You will have your fan working again.
By the way, before you get to do this, you need to remove the glovebox... Not just the glovebox door, then entire glovebox...
Old Feb 5, 2005 | 05:33 PM
3rdmaxse0's Avatar
u can fix the clunking of the motor mine was clicking and when i swapped my ACC in i took it apart and cleaned all contacts and works fine now and my fan never seems to blow at full speed it seems 3 and 4 are the same but if i go in diagnostics it blows faster. is that normal
Old Feb 5, 2005 | 05:58 PM
mtnbikeair's Avatar
My car must be dyslexic, it only works on 1,2 and 3, but four doesnt work
Old Feb 5, 2005 | 06:13 PM
or it's the hi blower relay like internetautomar told you in the other thread
Old Feb 5, 2005 | 06:40 PM
mtnbikeair's Avatar
i was just making a joking comment, wasnt trying to figure out the problem because as you said internetautomar told me already.
Old Feb 5, 2005 | 07:02 PM
Pyrophilus's Avatar
When Craig tells you what he thinks it's wrong, he is most likely correct... I mean, HUD's don't lie... (still envious by the way...)
Old Feb 5, 2005 | 07:11 PM
Pyrophilus's Avatar
I am almost convinced that in the "Auto" or "Econ" mode (fully automatic fan control), the fan speed actually isn't four speeds, but variable. In my ACC, in the automatic fan mode, even though the fan display says "two fans", I can hear the blower starting to blow little faster as the interior temp of the car gets bit warmer. This has been doing this since we got the car new from dealer back in '92, and dealer said it was perfectly normal. I too noticed that in diagnostics mode, 4 blows alot faster than 3.
Hey, how did you get to the intake door unit (to take it out)? I mean, in the picture, it's really buried in there behind the metal bar, and next up against the cooling unit... Do I need to remove the blower motor housing?
jmlee44
Oct 2, 2022 02:13 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
