I put 20s on my max and drop it 2 inches...need help
Old Feb 14, 2005 | 05:49 PM
  #41
shavedmax's Avatar
the pic of my car 2 posts up is the most you will tuck on 20's with hydraulics, not bags. bags will not allow you to drop as low, there is no adjustability to that, theyre bolt on only. hydraulics you can play with heights
Old Feb 14, 2005 | 05:56 PM
  #42
expressinme's Avatar
thats false, bags u can adjust as much as u want. just with air
Old Feb 14, 2005 | 08:48 PM
  #43
goon9's Avatar
newb.... Sorry, but the bolt on bags will bottom out before they slam a max. Hydros are completely custom, not a problem with slamming it with a lil skill.
not a bad word on bags, i like em. But it has it's limits.
Old Feb 15, 2005 | 04:42 AM
  #44
shavedmax's Avatar
no offense, but ive debated this point a million times before, its your car, spend whatever you want to realize you were wrong and then spend more money correcting it.
you have to use bolt on mc phearson strut bags in the front, the ride isnt the same on air cylinders in the front, and with the width of your rim you CANT fit a big enough can(air cylinder) behind 20's to support the weight. even if you use the coil over style mc phearson bag, you are still limited to the height of your rim( the bag still has to sit on top of the tire. the taller the tire, the higher the car has to sit) on the other hand MY hydraulic cylinders sit in the same spot the strut does, but since i dont have springs, i dont need a spring perch, which means the height of the tire has no bearing on how high or low i can sit. i can set the height by where my cylinder is welded onto the strut housing, OR by the height of the stroke of my cylinder.
oh, and have fun making the back struts work with air. the strut housing is welded to the knuckle, no bolt on bolt off there.
if you really have questions about this kind of stuff go to streetsourcemag.com or layitlow.com
Old Feb 15, 2005 | 05:32 AM
  #45
well thanks for the infomation that is needed. Im really not an expert when it comes to adjustable suspension so thats why im askin someone who knows about it and owns it themselves. It never hurts to ask.
Old Feb 15, 2005 | 05:45 PM
  #46
shavedmax's Avatar
it doesnt hurt at all to ask, just dont tell someone they are wrong if you yourself arent an expert. civics have an upper and lower control arm, different suspension, the strut sits further in, so you can run cans on it with no problem. besides the fact that the actual body of a civic is different. you can put a 2 inch drop on a civic and it looks low. you do the same with a maxima and it looks stock. i practially scrape my floorboards, but the rockers are a couple of inches off the ground. the rockers and floor on a civic are almost the same height
Old Feb 16, 2005 | 09:04 AM
  #47
-shock211-'s Avatar
that paint job is nice.
Old Feb 16, 2005 | 01:16 PM
  #48
thanks for the comment
Old Feb 16, 2005 | 09:34 PM
  #49
DMad8724's Avatar
interested in you what you did to your grille? Is the center just gold plated or something? I like it
Old Feb 17, 2005 | 05:25 AM
  #50
No my grille is just stock but i took out the nissan emblem, later on i wanna get a billet grille cut out for the top and also that large space where the front lip is. Just waiting to get some money.
Lakersallday24
Nov 7, 2024 07:31 PM
dank4us
34
Jun 10, 2024 03:45 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
sc10692
Aug 9, 2015 09:37 AM
