Car doesn't start!!! Doesn't even crank until after 20 times
Old Feb 12, 2005 | 07:41 AM
1Fast03Max's Avatar
A few weeks ago, the car wouldn't crank until 10 turns of the key. Well, I tried to start the car this morning,(93 VE auto) and it wouldn't crank. Only the radio was on. Just a click and no crank. Then I put the hand brake down(worked right after i put e brake down before), and it still didn't work, Then i hit the brakes and moved it from park to 1 Just in case it was not in park. Still wouldn't crank. 10 more turns with the key , it finally started.
Old Feb 12, 2005 | 08:08 AM
oktobernick's Avatar
i had a problem like that in my 240sx. turned out i had a dead spot in the starter.
Old Feb 12, 2005 | 08:15 AM
dmontzsta's Avatar
Ford Only.
It definately sounds like your starter is gone, I would stop cranking it before you run down the battery and end up replacing that. The starter is a piece of cake to replace on the VE.
Old Feb 12, 2005 | 08:39 AM
eric93SE's Avatar
The starter in the VE is brushless permanent magnet (no dead spots possible). The VG on the other hand has brushes.
I'd check the nylon bushings on your tranny shift cable. there is a bushing at both ends, they usually break and fall off the car, then the ECU will not let the car start since it doesn't see that the car is in park.
Old Feb 12, 2005 | 08:52 AM
aminus21's Avatar
if it is the starter, tapping it with a wrench may make it work..then you'll know that the starter is bad.
also, take out the starter (very easy, remove negative battery cable first) and take it to a parts store; kragen, autozone, etc. they usually check them for free.
Old Feb 12, 2005 | 04:52 PM
internetautomar's Avatar
mod or sell?
Depends on automatic or manual.
The manual VE uses the same starter as the VG.
The auto VE is special
BTW the car won't start in 1st only neutral or park
Old Feb 12, 2005 | 05:11 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
can i take the auto VE starter and put it in my manual ?
Old Feb 12, 2005 | 05:19 PM
mod or sell?
Ve auto is not swappable with the VE manual that I'm aware of.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Balkins
Aug 12, 2015 06:39 AM
mrgooch
Aug 9, 2015 11:00 AM
