Altenator
Old Feb 21, 2005 | 04:59 PM
NewEngSurf's Avatar
Altenator
Looks like my altenator died Tried to drive the car to my house across town, made it about 3/4 of the way before the battery shat the bed. Altenator a do-it-youselfer? hard to get to? can i check it with a multi-meter, and where should i go about gettin one? Looks like im buying a new one and a battery
Old Feb 21, 2005 | 05:03 PM
Harvs94max's Avatar
its not too hard to replace local parts store will have it depending on what model you have its going to be about 150-200 for altenator and batterys are 50-100 i would suggest puting it in yourself youll save mucho mulla
Old Feb 21, 2005 | 05:38 PM
maxedout92max's Avatar
or if ur on a budget then go to a local pick a part/ junkyard and get it for 20 dollars .. its not hard to do ... battery............... harvs94max is right on the price ...
Old Feb 21, 2005 | 05:51 PM
lalo's Avatar
http://www.autozone.com/servlet/UiBr...3d801f46b1.jsp
JUST LOOK UNDER YOUR CAR FROM THE PASSENGER SIDE
Old Feb 21, 2005 | 07:34 PM
ArcticDC5's Avatar
Where is the drive belt adjusting bolt at?
Old Feb 21, 2005 | 09:16 PM
avmaldo's Avatar
It's that long brass colored bolt behind the pully that is between the udp and the ps pump pully. You have to loosen the adjusting pully center bolt first then adjust it accordingly.
Old Feb 21, 2005 | 09:46 PM
Vadim-93GXE
You can also get your alternator rebuilt and installed for around $120 with a warrenty from an alternator rebuild shop. Thats what I did about a year ago, no problems since.
Old Feb 22, 2005 | 09:00 AM
NewEngSurf's Avatar
this sucks, just got like half a foot of snow. Am i gona have to jack up my max to yank out that altenator? I gota pull it in my garage and get the wood stove started however due to my driveway i cant just roll it in cuz its on a hill. When i buy a new battery is it cool to throw that in and move it on only a battery without the alt just so i can bring it into my garage, Cuz it looks like thats wut i did when i tried to drive it to my house from my friends.
Old Feb 22, 2005 | 09:03 AM
Jeff92se's Avatar
I'm needing a caw
Battery power only should be fine for a very short trip. Try not to use the headlights/stereo etc..
pedal2dafloor
May 27, 2004 02:03 AM
jmrader
Nov 5, 2002 10:49 PM
jwinn
Oct 26, 2001 08:10 PM
