heater question
Old Feb 25, 2005 | 11:23 AM
RideTuner's Avatar
heater question
sorry if this has been asked already, my dads 3rd gen's heater hasnt been working for a while now, is this a known problem with the 3rd gens? is there a fix to it?
i tried searching the faq links but i couldnt find anything.
Thanks in advance.
Old Feb 25, 2005 | 11:51 AM
erty67's Avatar
Decal Specialist
what is it doing? blowing cold air? no blowing at all? not turning on?
Old Feb 25, 2005 | 12:33 PM
Wiking's Avatar
Thanks in advance.
1. Yes.
2. Yes.
Do the legwork. Few pages towards the freeze of the winter, it was topic no.1.
For some reason faqs & stickies do not really stick on these down to earth matters...
Old Feb 25, 2005 | 12:48 PM
RideTuner's Avatar
its blowing cold air, even when the car warms up fully it never blows anything but cold air
Old Feb 25, 2005 | 12:59 PM
garbury's Avatar
just a check, but did you make sure the little lever all the way on the left is closed? If not, it will suck in outside air and be cold...I'm sure you've already checked that but just in case
Old Feb 25, 2005 | 01:03 PM
RideTuner's Avatar
yeah, tried every setting possible
Old Feb 25, 2005 | 02:19 PM
erty67's Avatar
Decal Specialist
I made that mistake
you may also want to try changing out your thermostat. last thought is heater core Thermostat should be your next step, imo. Is your water temp gauge going up to a normal level?
Old Feb 25, 2005 | 02:38 PM
internetautomar's Avatar
mod or sell?
you've gotta gotta bleed baby, gotta bleed for it baby
Old Feb 26, 2005 | 02:06 AM
RideTuner's Avatar
thermostat was changed, heater still doesnt work
anything else besides replacing heater core?
Old Feb 26, 2005 | 03:16 AM
Wiking's Avatar
Yes.
Test the heater flow valve under hood. As told on those threads...
- vacuum powered. Vacuum present?
- electronics controlled. Is it? coil ok?
- bypass it. Now heats?
and so on and so on and so on. It pays to check the forum first.
Old Feb 26, 2005 | 05:49 AM
erty67's Avatar
Decal Specialist
did a search for heater....
http://forums.maxima.org/search.php?searchid=205328
hope that helps
Old Feb 26, 2005 | 10:43 AM
Wiking's Avatar
hope that helps
...helps to gouge t his mess age:
YOU do not have permission to access this page. This could be due to one of several reasons:
1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation
Old Feb 26, 2005 | 11:17 AM
erty67's Avatar
Decal Specialist
aw crap....i thought it would show, but probably not cause you didn't donate.
Old Feb 26, 2005 | 11:33 AM
erty67's Avatar
Decal Specialist
try these. i didn't read through them. i just cut and pasted...
http://forums.maxima.org/showthread....ghlight=heater
Old Feb 26, 2005 | 01:38 PM
RideTuner's Avatar
thanks, i appreciate all the help, i'll read up on it.
Old Feb 26, 2005 | 05:43 PM
mod or sell?
I already gave you the most common answer to the problem you are describing.
Old Feb 26, 2005 | 10:23 PM
Wiking's Avatar
Abs true. Maybe its easier to seek than try such simple deed?
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
