Need instructions...
Old Feb 26, 2005 | 04:14 PM
PDubs's Avatar
...on how to:
(1) Remove center console for radio install
(2) Remove both rear door panels to replace window actuators
I haven't been on these boards in a while, but I seem to remember a member that had some pretty good write-ups on this stuff. Does anyone know the sn or homepage of the person to save time? Or can anyone tell me how to do so?
I have replaced the window actuator in the front (passenger) door before, but I thought there was a trick to the rear ones. Thanks.
Old Feb 26, 2005 | 04:41 PM
Chris Gregg's Avatar
Get Off My Lawn
This is basic stuff. Center consule is 4 screws. Remove Ashtray. 2 screws located directly below headunit. 2 screws: one in each bottom corner. Pull console out, unplug lighter and hazard switch. There you go. To remove Headunit, remove 4 screws, they are visable. Rear door panels: Remove ashtray, take out screw. Take flathead screwdriver and remove plastic cover down inside door handle, remove screws (one holding arm rest, the other holding the bottom part of the door handle. Take off plastic cap from door handle (at top), remove screw. Remove handle, remove plastic arm rest/switch assembly, disconnect wires. Pop bottom of panel away from door, unplug light. Your done. Just remember to replug the switch so you can roll the window down to get to the regulator/bolts attached to window.
Old Feb 26, 2005 | 04:50 PM
«§»Craig B«§»'s Avatar
both those are on page
(also in the stickies at the top of the forum)
Old Feb 26, 2005 | 08:07 PM
Josh's Avatar
i know some people(like me) are visual learners so here is a pics someone posted awhile ago.
Old Feb 26, 2005 | 10:39 PM
PDubs's Avatar
Wow, thanks for all the info guys! I also didn't realize they were stickied, my bad!
The Wizard
Oct 5, 2013 11:41 AM
02nismokiller
Apr 28, 2012 02:52 AM
L_U_D_I_AMaxima
Mar 1, 2012 08:57 PM
DomoMaxima98
Dec 6, 2011 03:47 PM
