Resetting the ECU after exhaust install
Old Mar 6, 2005 | 05:52 PM
Eric95se's Avatar
Is it really nessecary to disconnect the battery for a full 24 hour period to allow for the ECU to reset itself after an exhaust install (to allow the engine to adjust the flow rate or something I am assuming)? I have heard this but wouldn't it be the same thing to just unplug the battery for a second then re-connect it? Thanks!
Old Mar 6, 2005 | 07:50 PM
Eric95se's Avatar
anyone? it seems every post or site I look at gives a different amount of time. I am beginning to think all I have to do is thake the neg terminal connection off for a few seconds to reset it......... anyone?
Old Mar 6, 2005 | 08:14 PM
MrGone's Avatar
Heard of it, didn't do it
Old Mar 6, 2005 | 08:56 PM
avmaldo's Avatar
i just let it sit unplugged overnight and after about three days of short driving i did notice a slight improvement.
Old Mar 6, 2005 | 09:26 PM
LvR's Avatar
LvR
With a VG?
Old Mar 6, 2005 | 10:18 PM
hakentt's Avatar
No you don't need to do that. Disconnecting the battery cable for few minutes will do the trick. But for exast upgrade it does not need to be reset.
Old Mar 7, 2005 | 12:54 AM
Wiking's Avatar
Its not sec's, its minutes. Half hour or more, maybe ½night. lol.
The diff times might be because of diff ECU's. And different opinions at nissan R&D resulting in jokes in the FSM. The focused question is how long the ECU pcb condensators keep register memory chips up. Now try to research that. And then find out your ECU was made with some other components...
ECU's are/were made in china, malesia, indonesia -or- all of those plus x ...and who knows with which components on what date???? Arent we lucky that Bill gates has not his stocks on these. Yet. Oh, wait for the day we have windows communicating with highway honda viruses... or daewoo.
But whatsda problem? Is your maxima being driven 24hrs a day? Just loosen the cable long enough, some day or night...
Old Mar 7, 2005 | 05:58 AM
Tarzan's Avatar
Why not trying to read the FSM? It's all there.
Old Mar 7, 2005 | 06:17 AM
Wiking's Avatar
...yes. with all spicey flowers: the throttle turns 135 degrees. lol.
Old Mar 7, 2005 | 07:20 AM
LvR's Avatar
LvR
I don't know what/who exactly you are referring to, but its definitely NOT all there like you seem to imply........................
Old Mar 7, 2005 | 07:29 AM
dmontzsta's Avatar
Ford Only.
I just unplugged it for the length of the install and when I was done, plugged it back in, worked fine.
DanNY's Avatar
Ad·min·is·tra·tor
"technically" aren't u supposed to disconnect the battery when you work on your car
Old Mar 7, 2005 | 07:56 AM
MrGone's Avatar
I have a really bad habbit of never doing that
I did when I worked on the SAFC, which reminded me why I have a really bad habbit of not doing it
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
