How do I remove a 240sx steering wheel?
Old Mar 29, 2005 | 05:40 AM
ArcticDC5's Avatar
I saw at the yard a 240sx wheel in great shape last time I was there, didn't think about grabbing it. My question is, how do I remove the steering wheel and what tools will I need? Will I need a steering wheel puller tool that you have to buy at an auto parts store?
Old Mar 29, 2005 | 05:42 AM
Mizeree_X's Avatar
Getting back to his roots
Autozone will loan you a steering wheel puller for free I believe. I have to assume you'll need it to remove the 240SX one since you need one to remove a Maxima one.
Old Mar 29, 2005 | 07:01 AM
mtnbikeair's Avatar
Yeah all you need is a steering wheel puller. It will just bolt right on after the steering wheel cap is off, and it pulls it off really easy. I have a 240 sx wheel and i absolutely love it, too bad the new maxima i just bought has an airbag...
Old Mar 29, 2005 | 07:16 AM
ArcticDC5's Avatar
Ok, now that that question is answered. How do I remove the center piece from the 240sx wheel? Do I just peel/pry it off with my fingers?
Old Mar 29, 2005 | 07:25 AM
DanNY's Avatar
Ad·min·is·tra·tor
i thought it unscrews from the back.
oh and the steering wheel...if it's coming from a junked car get one foot up on the dash and 2 hands on the wheels and rock that sucker back and forth to get it out.
Old Mar 29, 2005 | 08:41 AM
Maxzilla91's Avatar
lmao.. i was gonna do that to get my wheel off the maxima so i can put on my 240sx wheel... but then it was really tight on there, so i figure i'll just go borrow a steering wheel puller at a shop.. i need to use the leather restorer on the 240sx wheel first anyway
Old Mar 29, 2005 | 08:53 AM
DanNY's Avatar
Ad·min·is·tra·tor
once i was taking a few parts off a 3rd gen from a mechanic guy that i know.
me: hey you have a steering wheel puller?
mechanic: a what? what he he11 do u need that for?
me: to pull the steering wheel off
mechanic: (gets in car...checks to see the center bolt it off...one foot on the dash and 2 hands on the wheel. 10 secs later he hands me the wheel) here you go.
Old Mar 29, 2005 | 08:58 AM
ArcticDC5's Avatar
Old Mar 29, 2005 | 08:59 AM
expressinme's Avatar
is it hard to realign the wheel back to the orginal spot? or when u put the bolts back in its already aligned?
Old Mar 29, 2005 | 10:53 AM
mtnbikeair's Avatar
When you take your old wheel of make sure that your tires are straight forward and that your steering wheel is centered. Then when you put your new steering wheel on, your car tires should still be pointing straight ahead, then you put it on where the steering wheel is centered, then your wheel will be inline with your tires.
Old Mar 29, 2005 | 12:42 PM
Cliff Clavin's Avatar
Way out West
LMFAO...
It isn't quite as messy to use a steering wheel puller, but takes a minute or two longer.
I think Danny's method is the best one for a junkyard car.
Old Mar 29, 2005 | 01:05 PM
MrGone's Avatar
only thing to add to Dan's
thread the nut back on a few threads, this way the steering wheel wont hit you in the face.
you can thank shavedmax for that one
Old Mar 29, 2005 | 01:09 PM
Jeff92se's Avatar
I'm needing a caw
You just bang on each end of the wheel and it sorta vibrates off. Or jiggle it off
Old Mar 29, 2005 | 02:34 PM
jwmaxse2's Avatar
That's funny
Does anyone else see the sexual connotations in that sentence? I don't even want to know what else you do in your car
Old Mar 30, 2005 | 06:12 AM
maximaboi's Avatar
Originally Posted by jwmaxse
That's funny
Old Mar 30, 2005 | 06:19 AM
Scope's Avatar
Im izz sexay
How can this thread be seriously this funny without anyone being flamed? That's an org's first.
Old Mar 30, 2005 | 06:29 AM
DanNY's Avatar
Ad·min·is·tra·tor
shut up junior!
better?
Old Mar 30, 2005 | 01:24 PM
Scope's Avatar
Im izz sexay
Thanks Dan I could always count on you.
Old Mar 30, 2005 | 07:38 PM
what tool to i use to take out the bolts holding the wheel?
Old Mar 30, 2005 | 07:43 PM
Maroon'dMaxSE's Avatar
a socket wrench.......
but u will need an extender...i forgot the size of that bolt but it hell aint a 10mm or a 12mm
probably a 15mm
Old Mar 30, 2005 | 08:15 PM
cuz its a wierd star looking bolt
Old Mar 30, 2005 | 08:48 PM
twinkle's Avatar
might that be because you have an iarbag?
Old Mar 31, 2005 | 08:52 AM
yea it an airbag
Old Mar 31, 2005 | 08:56 AM
Jeff92se's Avatar
I'm needing a caw
You need safety torx bits. I suppose someone will find some sexual reference in that also.
Old Mar 31, 2005 | 10:08 AM
jwmaxse2's Avatar
No I can't think of any in that post
Sorry man, I was just messing with you before
Old Mar 31, 2005 | 10:06 PM
twinkle's Avatar
any idea where to get them?
Old Mar 31, 2005 | 10:49 PM
hpro123's Avatar
What you need is a screwdriver bit, in all probability it is the same used for a NX2K airbag steering wheel.
Special bit that adapts to a 5/8" screwdriver socket rather than the traditional 1/4".
Order the T50H bit (this is the size used on NXs so if anyone can verify it is the same for 240s please do) at a NAPA autostore ONLY, it does not seem to be available elsewhere. It's a basic T50 bit but it's hollow and about $3.50-4.00 at Napa.
The H in the end of T50 indicates it is HOLLOW (with a hole in the middle of the bit that matches a post in the bolt's head). Check the bolt to see if indeed the HOLLOW part is needed since a regular Torx bit will not work there. Hence the suggestion for NAPA.
SOme have gotten it from Snap-On but at $20 for one bit it is overly expensive. Or, if the need is not too utgent, you can check eBay, sometimes you can get a whole set for like $20.
Chris
Old Apr 1, 2005 | 02:20 AM
twinkle's Avatar
ok, yea, I wanted it for my max actually, not for a 240, but yeat T50 sounds about right, just not sure where to get the safty ones, i'll check ebay
Old Apr 1, 2005 | 07:24 AM
internetautomar's Avatar
mod or sell?
snap-on has them
Old Apr 2, 2005 | 01:54 PM
snap-on has them
Snap-on is the $h*t.
Old Apr 3, 2005 | 01:01 PM
ArcticDC5's Avatar
Well, went to the yard yesterday. I hate inconsiderate peeps. Someone smashed out the sunroof on the 240sx. HAd to swipe all the glass pieces off the seat, then I realized the leather was all ruined from the rain, some nasty stuff was coming from water + leather. I did notice you need a screwdriver to loosen one screw so the center cover can come off also. I'll probably go back next week for the leather e-brake handle and some sensors off a low mileage engine since I didn't bring my wrench set with me.
Old Apr 9, 2005 | 02:24 PM
ArcticDC5's Avatar
Went to the yard to grab a 5spd ecu for my friends 5spd gxe swap. Saw an SE wheel in mint condition, asked how much it was and I took it off. loosening the bolt and hitting it a few times on each side did the trick. The only thing different was my cruise control harness, so I had to put my old one on the new wheel. $10 and 20 minutes later, a brand new looking steering wheel is installed.
My interior was restored with the following:
dash a/c triangle vents $3
dash clock $5
'94 SE thicker tweed armrest $5
89-91 SE replacement leather steering wheel $10
No complaints in that dept.
lowpost99
Oct 26, 2025 06:53 PM
dcam0326
Sep 8, 2015 11:02 PM
lowpost99
Sep 8, 2015 05:06 AM
jfl330
Sep 4, 2015 01:44 PM
coasterswim
Sep 2, 2015 07:43 AM
