intalling E36 lights
Old Apr 3, 2005 | 11:10 AM
ElVito1981's Avatar
I need help installing the BMW e36 headlights. I tried to use the instructions by SkyMax (found on the angelfire website), but there aren't any step-by-step pictures to go with the instructions. Can anyone help me out with some pics?
Old Apr 3, 2005 | 12:11 PM
goon9's Avatar
Read it again, it's the best resource. ALot of it is common sense... cutting metal out to make room.
Old Apr 3, 2005 | 12:40 PM
xnyc's Avatar
uh are you sure? theres 2 parts of his page. one is the instructions and one is the pictures..just use your common sense and follow wat the pics look like
Old Apr 3, 2005 | 04:24 PM
ElVito1981's Avatar
the pics aren't clear though, and they don't have any arrows or indications
Old Apr 3, 2005 | 04:28 PM
ozzombie13's Avatar
I will eat your children
if you cant understand it then maybe you shouldnt be doing it your self
Old Apr 3, 2005 | 07:26 PM
Scope's Avatar
Im izz sexay
With the Cefiro install I have no installation instructions nor pictures. But I now have basically no metal on my passenger side radiator support. Driver's side will get done sometime this week when the weather clears.
Now for some helpfull advice.
Take the stock headlight out then place the E36 headlight in. Find an area that is restricting you from placing the headlight in cut or make an adjustment then you're straight. That's the best info because you endup doing that anyway.
Old Apr 3, 2005 | 07:39 PM
mtnbikeair's Avatar
Another thing to make it easy is to take your time and be patient, like work on it some and then when you get frustrated go watch TV or do something else for awhile. Once you get mad at those headlights you can break bolts, rip out too much metal and only make things worse.
Old Apr 3, 2005 | 10:18 PM
aminus21's Avatar
Good advice....
Old Apr 3, 2005 | 10:56 PM
imported_Maxima_Mike's Avatar
Originally Posted by aminus21
Good advice....
My install took me almost two whole days to complete. Mostly because it was my first time attempting something like this, but I got it done and I think it came out pretty good at the time it was done (now it needs a little work for the covers to stay on). But yeah, take your time. The instructions are pretty good, there are some things that you just have to kinda figure out for yourself when you get there.
Old Apr 3, 2005 | 11:40 PM
5 ltr. beater's Avatar
that's really good advice; keep that in mind when I hit you up to help me do my E36 headlight conversion!
Old Apr 4, 2005 | 01:00 AM
aminus21's Avatar
me too..lol
Old Apr 4, 2005 | 02:52 AM
nissanmaduk's Avatar
could someone give me the web address where the fitting instructions are, I'd like to do the same conversion.
Old Apr 4, 2005 | 09:21 AM
OBEEWON's Avatar
I only looked at the instructions to see if it was worth the trouble, after that I just freestyled, mainly because only one other person on here has the E36's I have that I know of. Best advice I can give is cut a little bit at a time. its better to undercut than overcut. Oh yeah and be careful with your grill.
Old Apr 4, 2005 | 09:24 AM
maxima92se's Avatar
true true!! i made a mistake and overcut my grill. so i actually had to buy a new one. its not bad but if you look closely its not as straight as its suposed to be.
Old Apr 4, 2005 | 09:30 AM
tripleGmax's Avatar
um why the f did you cut your grille is my question......it seriously doesnt need to be cut.
Old Apr 4, 2005 | 09:46 AM
OBEEWON's Avatar
i didnt cut my grill, i meant to take it out for most of the fitment so you dont break the connections. And dont bend the part that holds the grill when you cut or your junk will be crooked, and its a biznatch to straighten.
Old Apr 4, 2005 | 10:02 AM
tripleGmax's Avatar
yeah i know you didnt cut your grille, but im wondering why anyone would.......i made sure i took my grille out because a broken grille isnt going back on a car.....
Old Apr 4, 2005 | 02:07 PM
goon9's Avatar
I cut my grill a tad on the side to make it fit PERFECT. And it did... Till I started to redo my lights.
Old Apr 4, 2005 | 04:53 PM
maxima92se's Avatar
that is exactly what i did inorder to ensure that the lights fit perfectly. And yes i amde a mistake in cutting them that is why i bought a new grill and that way i can redo them and maybe this time i can get them right.
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
