Tach Signal Wire (Remote Start)
Old Apr 9, 2005 | 06:09 PM
505max94se's Avatar
I've had remote start for a while and have had problems with it for a while. I had I friend install the alarm/remote start for free so I a can't complain. First off, when I remote start it when the engine is cold it will start and run for about ten seconds and then shut off. It will do this about three times but it'll never stay running unless the engine is warm. I helped him install the remote start and I remember that he had trouble finding the tach signal wire.
I have my interior completely torn apart right now because I'm installing dynomat, dying my brown interior black, and I installed my new my guages. While it's all taken apart I dicided that I'm going to fix my remote start. I already made it so it won't start in gear by puting a diode between the hood pin wire and the brown nuetral safety wire. I'm now looking for the tach wire coming out of the ecu because my friend who installed it did get the wrong tach wire. I looked on craig brace's how to page and it says the wire is "GREEN/BLACK/SILVER" and it's location is "2ND OR 4 CONNECTORS AT ECCS, PIN 7*". Well I've found quite a few green/black/silver wires coming out of the ecu. I just don't know what the location stated on his site means. Can someone please help me out?
Old Apr 9, 2005 | 08:07 PM
505max94se's Avatar
Does anyone know exactly where the tach signal wire is? Thank you in advance.
Old Apr 9, 2005 | 08:22 PM
internetautomar's Avatar
mod or sell?
I'm pretty sure you can tap off one the coils, I just don't recall which wire to tap into.
Old Apr 9, 2005 | 08:26 PM
blacks92seAuto
you know, thats funny..I have been havnig troubles with my remote start, killing the car from 15secs to 10 minutes after it has been running....The tech who worked on my car today said something that when they first installed it, they did not tap into the tach wire at all...but when they did, they said it wouldn't work at all...........
Old Apr 9, 2005 | 08:32 PM
505max94se's Avatar
It is tapped into the coil wire right now and that's why it's not working right.
Old Apr 9, 2005 | 08:34 PM
subs1000w's Avatar
you can get a remote start to work without using tach. its called voltage sencing mode, basicly it sences when the voltage goes from 12.5 to 14 once the engines runing and the alternators charging
i have mine hooked up to an injector wire which also works fine but to test to see if the wire will work for tach use a miltimeter switched to AC voltage and the tach wire should read in the single digets with the engine idleing but when you give the car gas and the rpms increase the AC voltage should increas at least double or triple in higher rpms
Old Apr 9, 2005 | 08:59 PM
505max94se's Avatar
There are three wires that are green/black/silver that are coming out of the ecu. One of them is probably the tach but I can't test them because my multimeter's battery is dead. I'll figure it out tomarrow.
505max94se's Avatar
I've tried the voltage sensing mode in the past and it didn't work but, thanks anyway.
Old Apr 9, 2005 | 09:09 PM
blacks92seAuto
what is the purpose of the tach wire?....sorry im new to this thing
Old Apr 9, 2005 | 10:06 PM
505max94se's Avatar
I believe it let's the alarm/remote start unit know that the car is running so it doesn't keep trying to start the engine.
Old Apr 9, 2005 | 10:50 PM
MrGone's Avatar
You can actually pull the engines speed out of the electrical system on the car.
For the tach wire, check my SAFC write up.
Old Apr 9, 2005 | 11:04 PM
505max94se's Avatar
thanks
Old Apr 10, 2005 | 11:30 AM
MrGone's Avatar
There is equipment that can sense the pulses in the electrical system and will tell you the engines speed.
The Frye
Sep 2, 2021 11:03 AM
minsbang
Sep 11, 2015 08:48 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
