ks wiring harness replacement
Old Apr 12, 2005 | 05:30 AM
maximaboi's Avatar
ok when I got the car the knock snsor was already replaced but the wiring harness got pulled loose or something so all I need is to replace the wire that goes from the front drivers side of the engine down under the intake. what do I need to take off to get to the other connecton so that I can put the new wiring harness on?
Old Apr 12, 2005 | 08:04 AM
Wiking's Avatar
I suppose ? the other end of that wire is inside KS, under the exhaust manifold, VGE-engine...
Old Apr 12, 2005 | 08:18 AM
internetautomar's Avatar
mod or sell?
he's a VE it's under the intake
Old Apr 12, 2005 | 09:33 AM
eric93SE's Avatar
Its in no way an easy job, and the lower intake manifold gaskets are expensive. How do you know its bad. Did you check the resistance?
Old Apr 12, 2005 | 11:22 AM
maximaboi's Avatar
I know its bad because the other end of the wiring harness is not connected to anything. it looks like that clamps on the other end came loose and the wires came out. I bought the car like this so I dont know how it really happened. the resistor is in there right now but I have heard bad things about leaving it like that so I want to try and get this taken care of soon.
Old Apr 12, 2005 | 06:05 PM
usmanasif's Avatar
You'll be wise to do so. Check Autozone DIY site for help.
Old Apr 21, 2005 | 06:07 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
its just unplugged with the resistor in it, you have to take the upper and lower intake off, its a time consuming job but not hard
Huttig2009
Sep 25, 2015 03:31 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
