tensioner wheel/pulley
Old Apr 13, 2005 | 06:07 PM
90MAXGMG's Avatar
After I replaced my alternator my car started to make this horrible squealing noise...thats when I noticed that when we took off this part (I know now that we didn't need to) we had not replaced something that looks kinda like a washer. My mechanic said that this is where the noise was coming so I went to salvage to get it and after they put it on it still makes the noise! what else could it be?
Old Apr 13, 2005 | 06:11 PM
Scope's Avatar
Im izz sexay
Are your belts tight? It sounds like you didn't tighten your belts up. How far can you push down on your alternator belt.
Old Apr 13, 2005 | 06:14 PM
90MAXGMG's Avatar
I dunno I'll go check...right now. Thanks for the quick response
Old Apr 13, 2005 | 06:20 PM
90MAXGMG's Avatar
I'd say its around 1/2" give or take a little
Old Apr 13, 2005 | 06:30 PM
Scope's Avatar
Im izz sexay
That sounds good I remember when I had a slipping belt it did that until I had it adjusted. Try adjusting it a liitle tighter so there's a 1/4" slack.
Old Apr 13, 2005 | 06:53 PM
90MAXGMG's Avatar
ok...will do, thanks and i hope it works!
Old Apr 13, 2005 | 06:57 PM
DARHAW-MAX's Avatar
It is not the washer. The actual tensioner pulley has a bearing inside that will seize up. When the bearing seizes, it prevents the pulley from rotating when the bolt is tightened down. The same thing happened on mine. You can either go to any parts store or a boneyard and get the pulley. I opted to purchase two new pulleys: one for the altenator belt (the one that was bad) and one for the power steering belt (to offset a future failure).
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
02PearlSE
Feb 1, 2016 12:37 AM
maxperformance
Dec 13, 2001 12:13 PM
ejj
Sep 22, 2001 01:04 PM
K Simmons
Mar 9, 2001 05:54 AM
