Trunk pop wire
Old Apr 16, 2005 | 09:40 AM
bhunter's Avatar
Trunk pop wire
I've just installed my keyless entry system and it works pretty slick. I could not identify the solid brown wire for the trunk pop. The door lock/unlock wires were on the door lock timer harness. The horn wire was on the stock alarm harness. I found those easy. Where EXACTLY can I find the trunk pop wire?
That job was this morning. This afternoon I get to entirely replace my daughter's Blose system
Old Apr 16, 2005 | 09:53 AM
Michael's Avatar
Back in a 3rd Gen.
Quote below is from this link
"Trunk Pop: Solid brown wire: This wire can be found in the drivers kick
panel but for me it was easier to trace it back where there were fewer wires
under the rear seats.
Also, you'll need a relay to convert the - trigger to a + signal. Wire pins 85 and 30 to a constant +12V source, pin 86 to the - trigger, pin 87 to the + trunk wire in the car
[Personal Note] An SPST Relay with 4 pins will work for this. Original writeup calls for SPDT."
Old Apr 16, 2005 | 04:10 PM
bhunter's Avatar
That's the link I used to get as far as I did. I need to find it in the kick panel, it's got to be there as it comes from the door. If nobody knows exactly I guess I can take off the door panel and put a toner on it.
Old Apr 16, 2005 | 06:50 PM
ghostmax's Avatar
I found it at the lower left corner panel (much easier to get to)--not at the door or SMJ. If you remove it, then there is a chunk of wires taped together. It's in there, but I had to test like 5 different brown wires. Btw, it is a thicker wire than the ones at the alarm box.
Mahmuth
Aug 16, 2024 08:23 PM
REDinLV
Aug 15, 2024 12:30 AM
D Mason
Jun 21, 2016 04:43 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
