Stock Timing
Old Apr 19, 2005 | 11:04 PM
  #41
3rdgene's Avatar
not in the throttle body....beside it.....i believe we use IAT/MAF combinations
Old Apr 19, 2005 | 11:05 PM
  #42
LvR's Avatar
LvR
Originally Posted by 3rdgene
basically when the engine compartment heats up the ecu loses accuracy and the chip corrects it
What a pot of snot!
  #43
91WBSE's Avatar
[QUOTE=Wiking]Hmm yes. My finger comes out blk from that tst. How about yours?
QUOTE]
On my 91 SE tailpipes are perfectly clean inside........the inside of the stock muffler is still kinda shiny....it has 222k on it too....alot of water comes out of my exhaust in the mornings.
Old Apr 19, 2005 | 11:06 PM
  #44
3rdgene's Avatar
guess some of us arent as educated as others LMFAO
Old Apr 19, 2005 | 11:08 PM
  #45
3rdgene's Avatar
what do u thing is connected to your IAT Plug.....u have to have a plug.lol
Old Apr 19, 2005 | 11:09 PM
  #46
3rdgene's Avatar
look in your manual you would be amazed
Old Apr 20, 2005 | 01:01 AM
  #47
LvR's Avatar
LvR
and
and
Those comments coming from somebody that initially stated very confidently that
well this chip is only active at WOT
Now if you are even slightly educated in the fuel and timing management systems of the Max as you would imply, you would be able to appreciate that by inserting a single black box in the ECU's temp compensation loop from the MAF, there is simply no way for the "chip" to only be active at WOT because it simply wouldnt be able to know when that situation arrives by only looking at underhood temps and while its connected to the MAF temp comp loop only.
So just to restate the obvious :
1. This thing does not work at WOT only - if it actually ever does.
2. If it does anything at all, then this thing affects the whole of your airflow metering system at all times irrespective of throttle position
Now if you want to continue with an intelligent conversation, stick to facts and - not in the noises containing technical terms you found in the write-up of the "chip" or the FSM.
Old Apr 20, 2005 | 08:48 AM
  #48
3rdgene's Avatar
u must of missed the post where i said i was going to make an override switch...That would only be necessary if his paper work was a lie
Old Apr 20, 2005 | 11:06 AM
  #49
3rdgene's Avatar
amazing how this thread ended up like this when i simply asked what the stock timing was for our car. Now i know why your name is LvR...ur just a hell raiser thats it....show me your 5 star car on cardomain then u can tell me something until then SHESSSH!!
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
homeyclaus
Sep 3, 2015 06:15 PM
sonic7
Aug 20, 2015 12:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
