Help!!! black smoke, rough idle, studdering engine then dead
Old Apr 24, 2005 | 04:32 PM
Studio718's Avatar
I changed my air intake and started driving..my car starts studdering, idle from 0 to 1k up and down, black smoke comming from the exhaust and then..when I go over 3k it dies..when i let off the gas..whats wrong here?
Old Apr 24, 2005 | 04:41 PM
Matt93SE's Avatar
STFU n00b!
you screwed something up sounds like.
did you get your MAF plugged in? pointing the correct direction?
all vacuum hoses hooked up?
Brendan's Avatar
i dont konw about the smoke but when i put my cone filter on i forgot to cover the hole on the bottom of the tubing and my car would barely run and then die untill i covered it up
Old Apr 24, 2005 | 04:42 PM
89 Black Max's Avatar
Sounds to me like you have a mass airflow sens problem
Old Apr 24, 2005 | 04:45 PM
Studio718's Avatar
what hole on what tubing?
there is a hose comming from my tranny i dunno where it hooks up 2 thou.
Old Apr 24, 2005 | 04:46 PM
Studio718's Avatar
I didnt even unplug the sensor, I just added the aluminum piece where the two hoses attach to, cut one of the hoses a bit cause it was 2 long and connected em.
then I started the car and it started idling rough, black smoke comming from the Y pipe section and muffler.
Old Apr 24, 2005 | 04:47 PM
Studio718's Avatar
oh I took off the resonator also.
Old Apr 24, 2005 | 05:14 PM
blacks92seAuto
did you plug the resonator hole?? you said you started it and forgot to, so you plugged it up,, but this was after you started it right? im guessing your engine caught a nice suction of dirt and debris
Old Apr 24, 2005 | 05:17 PM
Studio718's Avatar
no i changed it completely with a piece that only has the two holes 4 the two black hoses
Old Apr 24, 2005 | 05:20 PM
Studio718's Avatar
No someone gace me an aluminum piece with the two holes, I removed the part with the resonator, attached the aluminum piece to the throttle body, connacted the MAF and the filter.
started the car up and whoola, trouble.
I couldnt get the sensor 2 disconnect after trying 2 pull it off so I never touched it.
Old Apr 24, 2005 | 06:21 PM
Studio718's Avatar
ok I changed the MAF and it works perfectly , hehe thnx guys.
CorollaULEV
30
Aug 9, 2021 08:11 PM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
