ABS freaks out al the time, what to do?
Old Apr 24, 2005 | 10:12 PM
CyMax's Avatar
All right, I'm frustrated, my ABS goes off when I back up turn and stop, when I take low speed sharp turns, other odd times. Should I change out all the fluid, and see how it goes or what. This scares me I don't want the brakes to go at the wrong time. Any ideas??
Old Apr 24, 2005 | 10:18 PM
DaWifey's90's Avatar
what can my max do for me
have you had any recent trauma to the vehicle?
Old Apr 24, 2005 | 10:21 PM
CyMax's Avatar
Nope, bought it about 7k ago and it's done it almost from the start.
Old Apr 24, 2005 | 10:25 PM
ghostridden's Avatar
mine does the same thing, somethign to do with the computer so i was told, so i just took out the ABS fuse, keeps it from spazzing out on me, mine will engage even when i'm driving down the road
Old Apr 24, 2005 | 10:45 PM
Bill Brasky's Avatar
Seperated at Birth?
don't use the brakes
Old Apr 24, 2005 | 10:50 PM
twinkle's Avatar
I have an ABS computer (I dont need) if anyone wants to buy it
Old Apr 24, 2005 | 11:02 PM
is it that the abs actually activates or does the light just stay on or flash a bit?
assuming that you're actually getting false abs activation -
the first things you'd want to try is to be sure that all four wheels are getting equal hydraulic pressure - but that's easier said than done - also raise each wheel and check for up/down and left/right movement - if the hub is loose well then there you go.
definitely look into the sensor - excitor gear set up
these are located at each wheel just behind the wheel mounting flange..
be sure to clean all the crud out with brakekleen or whatever. i believe the clearance between the teeth and the sensor is a max of 1 mil
let me know if you're getting any codes vs actually activation
Old Apr 25, 2005 | 12:18 PM
greggie195's Avatar
same thing happened after the axle was changed. Sometimes it activates at every stop, other times the light just comes on. Code for me is 6-front right sensor, the same one with the new axle. I just been too lazy to look at it. In my case it doesn't affect my driving because after a minute of driving the light always comes on. I've heard that this could be caused by a dirty sensor. If the light ever does come on, try to get a code read on it.
Old Apr 25, 2005 | 12:33 PM
twinkle's Avatar
well, if it started after you changed the axle, it could be that its A the wrong axel (no ABS gear) for B the sensor could be too far away now....
Old Apr 25, 2005 | 01:26 PM
CyMax's Avatar
My light dosen't go off but the abs definately is going off. I can hear and feel it in the steering. I'm going to replace 100% of the brake fluid, rebleed and clean the sensors, that should, if nothing else take an afternoon.
Old Apr 25, 2005 | 01:30 PM
Jeff92se's Avatar
I'm needing a caw
Who ever chanced the axle didn't unbolt the abs sensor and stretched/damaged the sensor harness. Now you get to pay more for a new sensor than you did for the axle.
Or if you get lucky, you can find one in the boneyard.
Old Apr 25, 2005 | 01:36 PM
tripleGmax's Avatar
thats what i was thinking....
could you just pull the abs sensor and be ok?
Old Apr 25, 2005 | 01:39 PM
Jeff92se's Avatar
I'm needing a caw
Sure. Just like you could pull the 02 sensor, cylinderhead temp sensor, knock sensor etc.....
Old Apr 25, 2005 | 01:40 PM
tripleGmax's Avatar
i meant fuse.......give me a break please. oh and people read top to bottom, so you should type below a quote......
Old Apr 25, 2005 | 01:43 PM
89badmaxse's Avatar
if you need a abs pump or comeputer i have 2 comnputers and one pump for sale.
Old Apr 25, 2005 | 01:45 PM
Jeff92se's Avatar
I'm needing a caw
Hell no...
Old Apr 25, 2005 | 01:47 PM
tripleGmax's Avatar
ok sounds good!
Hell no...
Old Apr 25, 2005 | 03:35 PM
greggie195's Avatar
yeah Im pretty sure the sensor or cable is shot, I know the ABS wheel is there, and Im in no rush to get it fixed, I've driven for 7 years without ABS. It would be nice to have, but not a necessety
Old Apr 25, 2005 | 07:48 PM
internetautomar's Avatar
mod or sell?
you need ABS???
Pansie!!!
just pull all the friggin' fuses for it.
Disclaimer:
any advice given in this thread or any other is to be followed at your own risk and poster accepts no liability for any incidental or consequential damages or consequencws.
in other words: if you **** up it ain't my problem
Old Apr 25, 2005 | 09:04 PM
CyMax's Avatar
you need ABS???
Pansie!!!
Disclaimer:
Silly!! Really I dont care if I have it or not I just want to KNOW if I have it or not, know what I mean? So any ideas would be good. Thanks!
Old Apr 26, 2005 | 12:34 AM
Wiking's Avatar
Originally Posted by CyMax
...any ideas would be good. ...
Any ideAs:
- take the ABS computer out, clean harness connector and computer box connector pins (I added contact grease to all pins...)
- clean all groundings...
clic: http://www.cardomain.com/memberpage/748507/10
here's some connectors to clean...
AnsonJ
Jun 2, 2017 01:35 PM
Tiniform
Dec 25, 2015 07:40 AM
305head
Aug 26, 2015 09:03 PM
2k0to2k3
Aug 18, 2015 09:59 AM
