vent problem
Old May 15, 2005 | 07:37 PM
swowlinc's Avatar
1993 SE
vent problem
I have a/c but for some reason my hot/cold lever wont move over past the mid point on the temp scale. Ive taken the dash apart and still cant find the cause of this. I cant use my a/c right now. Anybody know what the problem could be?
Old May 15, 2005 | 07:39 PM
mtnbikeair's Avatar
I dont know, but mine wont go to the last 1/3 of the cold part.
Old May 15, 2005 | 11:20 PM
Wiking's Avatar
The ctrl wire stuck? Maybe the flap it adjusts is stuck as seals worn? Try exercising and lubricatin the flap (blu at the pic) adj wire...
Old May 16, 2005 | 05:06 AM
disgruntled's Avatar
Also a suggestion is that try moving the lever while the fan switch is set to the OFF position. I don't know why, but when my fan is set the maximum position, the heat/cold lever won't budge until I move the fan switch to a lower position.
Old May 16, 2005 | 08:20 AM
swowlinc's Avatar
1993 SE
Thanks yall, I'll see if anything works.
Old May 16, 2005 | 08:39 AM
JDwyer2821's Avatar
I have to say you have a giant stash of random but useful diagrams/pics
Old May 16, 2005 | 08:43 AM
yandianj's Avatar
I had this same problem. Most likely the plastic track that the slider rides on has cracked due to age and is catching. Replace the whole thing with one froma junkyard or ebay.
Old May 16, 2005 | 10:04 AM
Wiking's Avatar
Actually this prompted to make an inventory of my max files: 2.0Gb 2531 files /2yrs.
Somebody donate me VE, and pics will flow...
Old May 16, 2005 | 03:30 PM
Maximum Depth's Avatar
I have to do the same thing. I wondered if it was a bent control wire, but haven't taken mine apart to look at. For now, I just move the fan switch to the left before changing the temperature setting.
Old May 16, 2005 | 05:30 PM
Nickpisp's Avatar
Friend of mine did the same thing.
Old May 16, 2005 | 06:00 PM
swowlinc's Avatar
1993 SE
Well, I tried everything suggested, but the thing still wont move to the cold side. I took it out and examined the unit and the cable and could see nothing wrong. Maybe next, I'll just take out everything in there ,but not today. Oh well, I aint driving it anyway.
Old May 17, 2005 | 01:30 AM
Wiking's Avatar
Originally Posted by swowlinc
... Oh well, I aint driving it anyway.
To me that assy looka PITA: explode whole dash for one flap! nooo... I would try to take cooler unit off ? (is it feasible?) to access it. If not, maybe? take a solder and carver big enough hole to the side to access the flap and its mech. Then close the hole with silicon or whatever. Dunno, not there yet...
t6378tp
Sep 29, 2018 04:27 PM
Smackasmith
Feb 1, 2016 12:40 AM
homewrecker
Sep 24, 2015 07:01 PM
spidgeon
Sep 9, 2015 03:36 PM
