pulling motor question
Old May 22, 2005 | 01:44 PM
Dysfunctional
where do i bolt the puller up 2. i know this sounds stupid but i just would like some guild lines to follow. so anyhelp would be greatful. i would search ... but that options is not allowed by me? b/c im not a donating member, which i plan on doing. ANYWAYS. yeah could someone post pics or a site on where to bolt this baby up !! i would appriciate it. thanks again
-Dys
Old May 22, 2005 | 01:56 PM
«§»Craig B«§»'s Avatar
we wrapped chains around the exhuast manifolds and pulled up on those. It worked fine that way
Old May 22, 2005 | 02:36 PM
mattcomet82's Avatar
isn't busted manifold studs a problem on the vg??? i wouldn't want to see his post after something went wrong there...
Old May 22, 2005 | 08:09 PM
Drivin Maxima's Avatar
Yea they are on both VG and VE I think. But picking up by the exhaust manifold is fine assuming the studs are not broken. I had slings to use, so I took two and brought then down through the exhaust manifold and wrapped them under the oil pan and back up the other side the same as the front. Worked fine for me.
Old May 22, 2005 | 08:50 PM
kiyakerz's Avatar
how do you know if your exhaust manifold studs are busted? I have an exhaust leak that I think is coming from the exhaust manifold, and I'm going to replace the gasket... does the stud have anything to do with it?
Old May 22, 2005 | 10:16 PM
Theres usually a distinct tapping rattling noise coming from the manifold area upon acceleration.
Old May 23, 2005 | 03:17 PM
vizslak7's Avatar
I will email you some attach point pictures of the set up I used. With the Tranny attached it balanced quite well during removal.
Old May 25, 2005 | 03:06 PM
Dysfunctional
ok sweet. i got ur email saying ur going to send me pics ... but none were attached. thanks though for your imput, i guess ill try the exhaust manidfold thing for now.
thanks everyone else, any more info would be greatly appriciated.
thanks,
-DYs
Old May 25, 2005 | 03:22 PM
vizslak7's Avatar
You need to email me so that I can reply with the attachments. Sending email through the forums does not allow for attachments.
JS
Old May 25, 2005 | 10:16 PM
brashncurn's Avatar
there is a loud clicking noise from the exaust leaking from the location of the broken studs. I replaced mine with hardened 300z studs. Yes, you have to replace the gasket also.
Old May 26, 2005 | 08:36 AM
Jeff92se's Avatar
I'm needing a caw
Any questions?
Old May 26, 2005 | 12:33 PM
Cliff Clavin's Avatar
Way out West
Originally Posted by Jeff92se
Any questions?
Yeah, where are the pictures of the engines being swapped in the Aztec Red Max? Those are much better...
Old May 26, 2005 | 12:37 PM
internetautomar's Avatar
mod or sell?
I've got better engine swap pictures but they're not involving a max
Old May 26, 2005 | 12:38 PM
Jeff92se's Avatar
I'm needing a caw
You mean that time where I let some hired day labor dudes with bottles of Tequila do an engine swap for $5/day + sandwiches??
Old May 26, 2005 | 01:09 PM
Hectic's Avatar
makes jury duty sound nice, they don't give you sandwiches though...come to think of it, they probably should at least give you lunch for $5-$10/day.
i think i can be counted in on a broken exhaust stud. sound goes away at normal operating temperature though.
Old May 26, 2005 | 10:19 PM
Way out West
That would explain the scratches on the fender
just messing with ya jeff...
Old May 27, 2005 | 05:11 AM
tripleGmax's Avatar
thats how mine started.....then it wouldnt go away after it warmed up. come to find out I had 4 broken studs, 1 on the front and 3 on the back. sounded like i had a munshkin under my car with a megaphone and a deck of cards it got pretty loud to say the least.
AcuraLegend
Oct 17, 2016 08:47 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
crazyespn
Sep 3, 2015 01:30 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
