randomally idoling at 1500 rpm
Old May 26, 2005 | 11:42 AM
3rdgene's Avatar
Every now and then my car will just jump up to 1500 rpm and the only way to get it to stop is shutting off the car and starting it again. The throttle cable isnt sticking and i cleaned my tps and it still does it?????
Old May 26, 2005 | 11:51 AM
Drivin Maxima's Avatar
Try cleaning the your IAC Valve...........
Old May 26, 2005 | 11:52 AM
3rdgene's Avatar
hummm.didnt even think about that....That is prolly the problem thankyou drivin
Old May 26, 2005 | 01:12 PM
91WBSE's Avatar
I had this same problem and turned out to be a loose connection on TPS connecter.
Old May 26, 2005 | 02:20 PM
Slamnasty's Avatar
I currently have this problem, though only when the car has been started cold. Fix duly noted.
Old May 26, 2005 | 02:31 PM
91WBSE's Avatar
Cold idle speed it supposed to be high. As the coolant temp goes up the idle speed will decrease. Mine starts and idles at about 1500, and if I let it sit there and idle it would settle down after about 2 mins, but I don't let it idle for more than 15-30 secs and I just drive normal.
Old May 26, 2005 | 02:44 PM
Slamnasty's Avatar
Well right, but mine does it a few minutes after moving, and in hot-*** AZ summers when it's 95 in the morning.
Old May 26, 2005 | 06:52 PM
3rdgene's Avatar
yeah mine has nothing to do with be cold...u can expect that with any car....i can be driving for 20 min with perfect idle and than buMMMMMMMMM 1500 rpm's.....I will check that tps connector again i guess
Old May 26, 2005 | 10:42 PM
Wiking's Avatar
Horses gulp intermittently too many blue *****, its probable when cracked ho(r)ses playing in the sun... Check out also PCV. (...and the mentioned IACV cleanup)
clics: http://www.cardomain.com/memberpage/748507/4
Old May 27, 2005 | 06:14 AM
3rdgene's Avatar
man wiking i noticed u got answers and pics for everything.....You are definitly one of the most usefull members we have...thankyou!
Old May 27, 2005 | 06:42 AM
Wiking's Avatar
Its good if smbdy can stand my typos; I'd rather be whole day photoshopping... All pics sit on the cardomain webpage.
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
slowlifer
Sep 8, 2015 05:53 AM
