Another A/C question...
Old Jun 8, 2005 | 10:52 PM
Brooklyn Legend's Avatar
I was at a shop and the tech tells me reason why my A/C is not holding a charge is because I have a leak in the hose (pipe) on the low side going into the radiator does that make any sense to anyone> if so what the fix to this?
by the way I had R12 system but just tried to convert to the R134A stuff/
Old Jun 9, 2005 | 06:16 AM
Wiking's Avatar
Hmm. If I remember right, Lea King is Plugg Ed.
Old Jun 9, 2005 | 06:51 AM
DanNY's Avatar
Ad·min·is·tra·tor
yup..replace the hose/line and you should be fine.
Old Jun 9, 2005 | 07:17 AM
I dont understand?
are you saying I should plug the leak with what?
Old Jun 9, 2005 | 07:26 AM
Wiking's Avatar
Well, I am told that I am warp Ed in my texts. Rightly so...
Do as Danny says, find that piece of piping and replace it. Then go smplace to have AC fillup.
Old Jun 9, 2005 | 07:10 PM
turns out its the condensor. refrigerant leaks right out of it. Can the condensor be plugged to seal the leak?
Old Jun 9, 2005 | 08:30 PM
Will's Avatar
I had my AC done a week ago. No, you should replace the condensor to be safe. When you do, also replace the receiver/drier (aka Water Tank Assembly) purchased from Nissan, and you should be fine. Oh, you also need 4 o-rings, 2 small ones and 2 bigger ones - again, buy from Nissan. If you do this at an independant mechanic shop, expect to pay around $600 total for parts, labour and evac+recharge.
BkGreen97
Apr 2, 2016 05:47 AM
Turbonut
46
Oct 21, 2015 08:28 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
EdRomo86
Sep 12, 2015 07:49 PM
