replacing engine-VE
replacing engine-VE
Hello guys,
as some of you may know, I'll be changing the engine in my "new" 92 se. The question that I have is this-will I have to remove the trany and the axles befire pulling the engine out? I've never done this and I am simply trying to envision the whole procedure before starting. Also, my father in law told me that I'll probably have to realign the clutch after I drop the new engine in. Do I need a special tool for that and pretty much some basic info will be really helpfull. How much time should it take? I have pretty much every imaginable tool. Thank you all in advance....
http://forums.maxima.org/showthread.php?t=391909
In the stickies. Don't ask me why it's in the MODIFICATIONS section when it's more of a repair. Ask mrgone about that.
Originally Posted by maximapitko
Hello guys,
Also you should just buy a new clutch for the engine cause youll have more than easy access to install it with the engine out. And with the new clutch kit will come a clutch allignment tool.
I would also reccomend changing the pilot bearing too cause its a $3.00 (litterally) part and if you dont and its bad on the new engine then your gonna kick yourself in the **** when you have to pull the tranny and everything to change it.
Other than that Good Luck and God Speed my friend.
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
