Changin Ac belt
Old Jun 18, 2005 | 08:37 PM
jigga123's Avatar
Changin Ac belt
I've decided to change all my belts. I've got the main one done but cant find the tensioner for the AC and alternator belts. BTW: I have a VG.
Old Jun 19, 2005 | 09:19 AM
Will's Avatar
Question: What do you mean by "the main one?"
AC belt: Loosen pulley lockut, and then look under the middle of the upper rad hose near your distributor cap cover. You will see a 12mm bolt head that will raise or lower the idler pulley. You want to lower to remove.
Alternator Belt: Loosen the 2 top mounting bolts so it can pivot, and then on the bottom of the alty, there is an adjuster bolt and and adjuster lock bolt. Loosen the lock bolt, and then turn the adjuster bolt to push alternator forward to ease tension.
Old Jun 19, 2005 | 09:33 AM
jigga123's Avatar
Sry about that, I meant cranksahft belt. Thanx I'll try to finish it off today.
VEvolution's Avatar
I miss my VE
I think he means the timing belt.
Old Jun 19, 2005 | 09:36 AM
Will's Avatar
I know. It's just that if one has done the timing belt, how did he/she do it without taking the accessory belts off first?
Old Jun 19, 2005 | 04:34 PM
GRNMAXDMON's Avatar
kinda funny not even i didn't catch that but then again im tired as hell.
05' MaximaMan
Oct 8, 2017 06:36 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
