Wheel Alignment Problem
Old Jun 25, 2005 | 09:35 AM
VEvolution's Avatar
I miss my VE
Everytime I get an alignment, after a short amount of time(3 months), the steering wheel begins to pull to the side, and the tires begin to be eaten away unevenly(especially in the inner parts of the rear tires). Doesn't seem that it should happen in such a short amount of time after getting an alignment. Also after each fresh alignment, the steering wheel is never perfectly straight. About a few centimeters off.
I asked a few people about what it could be, and these are the responses I got -
1)Check tire PSI(done, and it was fine)
2)Worn Tie Rods(should I do a "dry park test"?)
3)Worn out suspension components(suspension feels fine, except a bit too much body roll)
4)Alignment not being done properlly
Some other things, but I forgot...
Im about to purchase a set of brand new tires, get them balanced, and get an alignment very soon. I want this next alignment to be as perfect as possible. Can you guys give me any good advice on what I should check out, before going for the allignment itself? Thanks alot.
Edit: My steering wheel shakes when I go over about 60 mph. Could that be the tie rods and the cause of this alignment issue?
Old Jun 25, 2005 | 09:42 AM
maxitech's Avatar
I have the same problem. Even after an alignment, the car pulls SLIGHTLY to the right. No uneven tire wear, though.
Old Jun 25, 2005 | 10:29 AM
Wiking's Avatar
The lower ball joints go easily, raise wheel and check for play. None should exist. They are cheap; however, without proper tools pinion is a hard job to loosen...
The wide tires cause always changing pull on sides on worn groovy roads. Also worn axle bearings may cause problems. Power steering is one cause, actually there is one TSB for early 3gen models which explains whattodo in case of pull during acceleration.
Alignment is a DIY job, check out, click on:
http://www.cardomain.com/ride/748507/18
If the alignment is done only on one side (see pic), that results steering wheel being tilted. Not a problem, and may be corrected by repositioning steering wheel. (The alignment should be done by adjusting both side adjust screwss (2.) equally.)
lower ball joint R&R: www.autozone.com
Old Jun 25, 2005 | 10:42 AM
disgruntled's Avatar
I would hold off buying the tires until you can get your alignment correct.
As for suggestions, I would advise you to:
1. check tie rod ends, and check their conditions physically (look at them thoroughly)
2. physically check your ball joints
3. check and make sure your wheel bearings are not shot
4. check sway bar bushings
As for the rear, check sway bar bushings, and parallel link bushings, they are most likely goner.
Finally, make sure your lug nuts are tightened correctly, and do a suspension bounce test.
That's all I can think of right now. Hope others more knowledgeable can fill in.
Old Jun 25, 2005 | 11:07 AM
VEvolution's Avatar
I miss my VE
So normally, new tires are purchased after the allignment has been done? This is a hunch, but won't driving on the old beat up tires after the alignment throw the fresh settings off again?
Edit: I have done the "shock bounce test" and it passed with flying colors. Also the lug nuts are all tightened to 80 ft. lbs.
Editx2: I don't think the wheel bearings are shot. I would hear it.
Old Jun 25, 2005 | 11:08 AM
Drivin Maxima's Avatar
one question......have you been taking it to the same place from the first time, cause if so then take it somewhere else. Chances are if youve had it done that many times at one place then they are doing it wrong. But, make sure that you check all of the links and things mentioned earlier in the post also.
Old Jun 25, 2005 | 11:23 AM
Wiking's Avatar
Bad shocks result in patchy wear. Alignment is off, if wear is even all around, on the edges. Alignment does not change if u swap tires - at least if change is done properly. Go and read those given links, theres some great edu... no need for questions after reading those arTicles.
Old Jun 25, 2005 | 06:51 PM
A note to add, some places will do an alignment anyway even if some components are worn out/broken and will not tell you about it. As a result, your alignment will not hold because of broken components. Nothing really helpful, just a suggestion. Good luck though.
Old Jun 25, 2005 | 09:48 PM
VEvolution's Avatar
I miss my VE
Yeah, I know. Thats what I think happened everytime. They probably align my worn parts.
Old Jun 25, 2005 | 11:10 PM
Wiking's Avatar
...Editx2: I don't think the wheel bearings are shot. I would hear it.
Mostly yes, not always so. But you can feel it --->"...go easily, raise wheel and check for play. None should exist."
Old Jun 26, 2005 | 01:27 AM
warrior90t's Avatar
Mentally Hilarious
If you can't/don't want to do the alignment yourself, Sears does a good job. Also, they will refuse to perform an alignment if you have worn/bad/broken components.
Old Jun 26, 2005 | 11:23 AM
acidspit86's Avatar
sometimes they dont adjust the caster to compensate for road crown...
Old Jun 26, 2005 | 02:29 PM
Scope's Avatar
Im izz sexay
How much is Sears alignment? I was quoted 170 at some local shop and I ran out the door. They told me it is a two hour job plus they need the car for one additional hour for a "road test."
Old Jun 26, 2005 | 03:22 PM
tripleGmax's Avatar
that is crazy, i got mine at good year for 65
Old Jun 26, 2005 | 04:31 PM
anaximander's Avatar
It could be worn parts.
More likely though, you're either driving aggressively or driving on bad roads. Theoretically, you can **** up your alignment on the next turn out of an alignment shop on the next pothole. The situation is exacerbated with frontwheel drive since it's more prone to aligment issues than RWD. I know a corvette guy who hasn't needed alignment in 15 years.
Find a place that has 3-year or lifetime alignment options. That way you don't throw away hundreds of dollars every year. Tires plus is pretty good and some other chains like tire kingdom offer it as well.
Old Jun 27, 2005 | 05:28 AM
Scope's Avatar
Im izz sexay
how long does it take to align a car?
Old Jun 27, 2005 | 06:04 AM
Wiking's Avatar
Depends how good youre guessing. After each adjustment/tightening, you must re-check. DIY typical 5 to 30minutes, check 1minute.
One quarter adj turn means approx 1mm (1/25 inch) toe in.
matts95max
Apr 23, 2025 10:44 AM
dcam0326
Sep 8, 2015 11:02 PM
nbstriker10
Sep 4, 2015 04:26 PM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
