Doing timing belt, what parts do I need?
Old Jul 12, 2005 | 08:42 PM
  #41
Matt93SE's Avatar
STFU n00b!
Originally Posted by ArcticDC5
So, back on course...Does anyone know where I can get torque specs at for the timing belt job?
http://forums.maxima.org/showpost.ph...9&postcount=35
look up man.
Old Jul 13, 2005 | 01:15 PM
  #42
GRNMAXDMON's Avatar
Originally Posted by Matt93SE
Open your handy FSM. look on page EM-32. align the marks on the distributor as shown in the pictures, then install it. If you are standing in front of the car facing the back, it should be pointing at around 7-8 o'clock position, toward the front right corner of the car.
It SHOULD NOT be pointing at the 11 o'clock position as shown in the FSM.
As long as you align the marks according to the picture above it, then it will go into the right place. if it doesn't fire, pull it out, turn the engine a full turn, then do it again.
and piston #1 should be at TDC when i do this correct??? if so then i was right in the first place and i don't have an FSM at all but i do have a Haynes but i just wanted to ask here just to make sure.
Thanks Matt.
Old Jul 14, 2005 | 10:46 AM
  #43
aksansai's Avatar
01 Maxima SE, 5-spd
Originally Posted by maxima94ever
i have a 94 se it has 146,000 miles and i believe the timing chain has never been changed since i had the car from 49,000miles, can smebdy explain it to me if it has to be changed at 60,000. thank you
Provided you keep changing your oil when it needs to get changed, your timing chain is very resilient (it has to be to spin as fast until redline). It should theoretically require no maintenance for the normal life of the engine. If you do, however, have to remove the cover (for whatever reason), it would be a good thing to check the slack present in the chain (see the FSM for tolerences) to see if it requires adjustment or replacement.
Old Jul 15, 2005 | 04:52 PM
  #44
maxima94ever's Avatar
i do change the oil every 2,000 miles n now im using the toyota filter, i might have an oil leak around that area i have to check it if it's that cover i'll check the belt . thank you,
Old Jul 15, 2005 | 05:33 PM
  #45
ArcticDC5's Avatar
after this long thread, I may not be doing this after all. Just came back from test driving a 5.5 gen 6spd
Hondarydr
Dec 30, 2024 06:15 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Ray229Harris
Sep 16, 2015 08:16 PM
max_speed97
Aug 26, 2015 07:46 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
