Brake pads and rotor replacement
Old Jul 12, 2005 | 08:51 AM
MONSTERMAX's Avatar
I was wondering if anyone one new the bolts size i need to push the rotor off of the hub?
Old Jul 12, 2005 | 08:56 AM
kcidmil's Avatar
well if you're replacing the rotor anyway... beat it off. When I did mine, the stupid rotor stripped 3 bolts.
btw... I "think" (no quoting) that the size was a 10mm coarse thread.
Old Jul 12, 2005 | 08:57 AM
Greeny's Avatar
¯\(°_o)/¯
I might just be me but i do not understand the question????
Old Jul 12, 2005 | 09:15 AM
tripleGmax's Avatar
i dont really understand the question either, but the studs take 12x1.25mm lugnuts.
really weird question yo!
Old Jul 12, 2005 | 09:44 AM
MONSTERMAX's Avatar
I need to know the size of the bolt that you use to push the rotor off of the hub
Old Jul 12, 2005 | 09:53 AM
Mizeree_X's Avatar
Getting back to his roots
Pretty sure its the same size as the 10mm ones that hold 1/2 of the car together. I believe I pulled one off a radiator mount and used it to get the rotor off.
For those who are confused, many rotor manufacturers put threads on the hat of the rotor. If the rotor gets stuck on, you thread a bolt into them and it "pushes" the rotor off of the hub.
Old Jul 12, 2005 | 09:56 AM
kcidmil's Avatar
If the rotor is rusted to the hub (like mine were) it'll strip the bolts.
tripleGmax's Avatar
you learn something new everyday. thanks mizeree_X
kcidmil, mine were on pretty good when i changed my suspension, but i used a hammer and knocked/tapped it all around and it came loose finally and it shouldnt have stripped your threads, atleast it didnt on mine.
Old Jul 12, 2005 | 10:21 AM
kcidmil's Avatar
It took me 10 mins with a 5lb sledge to get my front right off. If that's any indication of how rusted they were. The rears came off easy, didn't even need the bolts. Front left was pretty easy. The bolts actually pulled that one off.
Should have seen the people's faces when I used the sledge (I was in a hobby shop) A guy came up and said "you know, you'll ruin your rotors that way" I just pointed at the Brembos sitting on the ground in the box
Old Jul 12, 2005 | 10:33 AM
Mizeree_X's Avatar
Supposedly the sledgehammer method isn't good for the CV joints either, buit I know lots of people who use it, and its not like you change the rotors once a month, so meh.
Old Jul 12, 2005 | 10:35 AM
kcidmil's Avatar
Sledge is no more harmful than driving over potholes and offroading. Or dumping the clutch and burning out.
Now maybe sledge directly on the joint.... hmmm
Old Jul 12, 2005 | 01:03 PM
Geerhed's Avatar
Moved on to BMW's :(
That would have to be a seriously old rotor in a seriously salty environment to get stuck on like that. I live and work on the oceanfront and have never seen that.
Still, a few sharp raps with a ball peen, or drive a wooden shim between the rotor and hub; should pop right off.
Best of luck
Old Jul 12, 2005 | 02:46 PM
kcidmil's Avatar
I live in the great state of SOUTH DAKOTA. They love to dump liquid salt on the roads at 1st sign of snow. Plus at the time the car had over 100,000 miles, and were the original rotors
I WANT OUT OF HERE!!!!!!!!!!!!!!
Old Jul 12, 2005 | 10:06 PM
West.Six's Avatar
you guys just replaced with stock brembro? there was a post earlyer of a guy selling brembo with a coating on em in zinc or black, dose that prevent rust? or is it just for looks? do you buy em like that or is it custom? anyone chrome plate theyer rotors? whats the biggest bbk you can fit on a 89 with 18's on front 20s on back?
Old Jul 13, 2005 | 07:25 AM
kcidmil's Avatar
check out this site for big brake kits.
www.mattblehm.com
As for the brembos. Mine weren't blanks they are slots. In fact mine are even a little more aggressive than the average ones that you can buy from internetautomar.
www.internetautomart.com But they are still stock size. Those are all I need though. I get braking performance out of those rotors alone.
Old Jul 13, 2005 | 06:54 PM
bvtran's Avatar
94c Big Max
goto pepboys and ask them, those studs goes for 1/pc.
Old Jul 28, 2005 | 07:24 AM
igzy's Avatar
I Know Kwaliti
Yup, just tried doing my rear rotors and man, they are STUCK solid. I tried using liquid wrench/steel brush around the center and hammering the sides and back but they did not even move. Will try the screw thing tonight. I did my front ones last week and I had to use a large puller to get them off. In the process I busted threads on one brand new puller and had to get another one to finish the job... PITA I tell you... Yes, I live in Canada and got lots of salt last winter, and to make things worse, since I had winter rims/tires on, the center of the rim was exposed so the rotors received nice salt and water treatment :-)
Old Jul 28, 2005 | 08:07 AM
DanNY's Avatar
Ad·min·is·tra·tor
you're referring to wheel studs right? there the lug nuts go on?
Old Jul 28, 2005 | 08:10 AM
DanNY's Avatar
Ad·min·is·tra·tor
zinc or black coating is for the rotor hat and rotor edge. they are non friction surfaces that usually rust. it's not a custom item...almost all on line place sells zinc plated rotors.
chrome plate? are you kidding me?
biggest BBK...how big is your wallet? you can prob work a 13" rotor in there.
18's front and 20's back....PICS???
Old Jul 28, 2005 | 10:28 AM
igzy's Avatar
I Know Kwaliti
I use standard rotors and a LOT of anti-seize (Loctite graphite) around the central mounting area and wheel studs :-)
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
