Exhaust studs +++
Old Jul 18, 2005 | 07:35 PM
Travis92se's Avatar
Exhaust studs +++
I know that this has been mentioned one thousand times but I still have questions, I am tring to change exhaust studs on my car. A little background is in order, Yes I have read the stickies. To be honest, I would not even own this car if it was not for guys like: Craig, Jeff, MrGone, internetmart, etc. but they have given me hope. I am still not sure that it is a good thing, however, I am in the process of changing my clutch and believe it or not I looked up and sure enough, two of my exhaust manifold studs are broke. I know how to fix the problem but I am looking for help on how everyone else would do it. Yes, I do understand how the exhaust works but I am looking for all the help I can get. I have removed both axles and the upper intake manifold. Now, i need to figure out if anyone else has been in this position. The rear exhaust manifold bolts have been removed but I did forget to remove the EGR pipe on the manifold side. I need help. I know that this will be easier with the car tore apart like I have now. I am currently planning on removing the rear studs until I can get the car put back together, then I will do the front studs.
Old Jul 19, 2005 | 03:36 AM
Greeny's Avatar
¯\(°_o)/¯
http://www.4dsc.com/articles/drivetr...ld_studs.shtml
http://forums.maxima.org/showthread.php?t=293668
Old Jul 19, 2005 | 06:09 AM
MrSector9's Avatar
I remved my egr on the intake manifold side. I honestly dont understand what you are asking here though since ther eis no real question.
If you woudl have read my post from like yesterday you owuld have read how I ddi mine and it turned out perfect.Use a mig welder and build them up until you can weld a nut onto them then they will spin right out.If you do not have a mig welder,well fidn someone that does or that can do that job for you pretty cheap.
BJ White
Old Jul 19, 2005 | 06:14 AM
Travis92se's Avatar
Yeah, I didn't really ask a question. I guess it was late and I was just frustrated. What I was getting around to was that I am in the process of removing the transmission when I found this. What are the options when replacing the studs with the transmission out of the car. I don't think the the engine will have enough support without the tranny mounts to remove the crossmember and loosen the rear motor mount. Thoughts?
Old Jul 19, 2005 | 06:49 AM
Mizeree_X's Avatar
Getting back to his roots
Read my post, I put a board on the bottom of the oil pan and supported the engine w/ a 3-ton jack and 2 jackstands.
Old Jul 19, 2005 | 08:05 AM
DanNY's Avatar
Ad·min·is·tra·tor
at this point...it might be easier to get a crane/cherry picker and pull the motor out a little and drill/weld/tap/grind/etc from above the engine bay.
Old Jul 19, 2005 | 08:14 AM
MrSector9's Avatar
actually i used a board on the poil pan for mine too since i foudn the motor dropped too much.. might be easier if you used jack stands and a jack since you could tilt your motor back to get at things easier
BJ White
Old Jul 19, 2005 | 05:09 PM
Konamonkey02's Avatar
does anyone have any idea how much it would cost to get this done at a shop?
Old Jul 19, 2005 | 05:40 PM
MrSector9's Avatar
expensive to say the least,call aorund and get some quotes or try to find some mechanic that even does work at home afterhours for cash, it is a long dirty job.. parts dont cost much but the labour is the killer.
BJ White
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
dcam0326
Sep 26, 2015 05:20 AM
