Tranny Change: For the Criminally Insane?
Old Jul 22, 2005 | 05:33 AM
Geerhed's Avatar
Moved on to BMW's :(
Before you post your advice, please know that the following thread is a bit old and it is only here in the 'recent postings' because my problem is solved and I posted the "end of the saga" further down. Thanks!
The tranny died in my 90SE Auto. I have a line on another from a local yard. I've done my own struts, starters, electrical work, engine work... but I've never pulled a transmission before.
I have all the necessary tools, and AllData subscription, and the FSM, but I'm wondering if this is a huge pool of quicksand to get into, or if it's a straightforward job. Have you removed/replaced your transmission, and did you find the job particularly difficult?
Thanks for your opinion(s).
Old Jul 22, 2005 | 05:42 AM
Wiking's Avatar
Originally Posted by Geerhed
... Thanks for your opinion(s).
My opinion is that its just work. Proper tools needed to keep sanity. Figure out all things which are worthwhile to replace simultaneously; seals, rubber boots etc...
Old Jul 22, 2005 | 06:04 AM
DanNY's Avatar
Ad·min·is·tra·tor
if you have jacks/stand that can lift the car high enough to clear the tranny...and then get it out of the car...you're 1/2 way there.
axles need to be pulled...tranny mounts..but otherwise it should be a straight shot.
Old Jul 23, 2005 | 03:23 AM
Phatsta's Avatar
Here you go. Complete guide on the whole job.
http://www.cardomain.com/ride/749143/2
Old Jul 23, 2005 | 03:28 AM
Phatsta's Avatar
Oh btw, the only tools I use are;
- Air tools (don't know the exact name in english though), with 12mm, 14mm, 17mm, 19mm, and 32mm except for wheel bolts which is stock 21mm unless you've changed them.
- Ring keys, 12 and 14mm.
- Pliers
- Screwdriver might be useful
Hmm... I belive that's it actually. Pretty straight forward job, it just takes a bit of labor and time.
Old Jul 24, 2005 | 08:44 AM
Geerhed's Avatar
I'll have to get the Ring Keys... or raid my father-in-law's shop.
I also have the air tools and found them priceless when replacing the struts.
How high does the car need to be lifted/supported to remove the tranny?
I intend to inspect/replace the CV's while I'm in there, but what other seals/gaskets would you replace while doing the job?
Time is not an issue: I'm a teacher on Summer Break so I have until the first week of September to get it done.
Phatsta: thanks for the write-up. I'll memorize that before starting the job.
BTW: I was lucky enough to find a junkyard tranny with 91,000 miles with a warrantee for $100 (the yard is going out of business). They have the SOHC engine that goes with it if anyone is looking.
Thanks for the great replies: keep 'em coming.
Old Jul 24, 2005 | 09:07 AM
Cliff Clavin's Avatar
Way out West
That's a good deal on the tranny.
I have never messed with an AT, but I know they are heavier than a manual, which makes it a pretty tough job for one person.
Since you are getting such a smoking deal on the tranny, I would use any extra money to get some kind of tranny jack or an adapter plate that makes it easier to use a floor jack, along with some good jackstands if you don't already have them.
MrGone and I took out my tranny to replace my clutch and flywheel. We ran into a couple of little snags, but it's still a pretty straightforward job. Like I said, though. I don't know about ATs.
Old Jul 24, 2005 | 09:31 AM
Geerhed's Avatar
OK: not to appear really dumb, but what are "Ring Keys"?
By your illustrations, Phatsta, it looks like you're referring to box-end wrenches, but is this some other tool of which I'm not aware?
Red92: I have an engine hoist which I'll be using to support the tranny, so I won't be needing a transmission jack (I think).
Old Jul 24, 2005 | 09:51 AM
barbersonly's Avatar
I have to put a transmission in a 91 SE. What is a reasonable price for one? Any good sites where I can order one?
Old Jul 24, 2005 | 09:58 AM
Wiking's Avatar
...really dumb, but what are "Ring Keys"?...
Not dumb, just need to learn sweDish... Maybe socket wrench?
Tranny lowered in, hoisted up: Needs only 2x4" sitting on strut towers and this, whatever u callit...
edit: btw, replace both axle seals 4$ ea.
Old Jul 24, 2005 | 11:26 AM
Geerhed's Avatar
Wiking: that is a ratcheting tie-down strap. Larger versions, with chain or cable, are called a "come-along." At least, on the Maine Logging Roads they are!
Old Jul 24, 2005 | 11:29 AM
Geerhed's Avatar
Barbers: try eBay. $350 - $800
Most local junkyards: $300 - $600
Aamco (as an example of a commercial shop -- but I wouldn't go there) quoted me $2,600 to do the job.
Old Jul 24, 2005 | 11:46 AM
Wiking's Avatar
...called a "come-along." ...
Maybe I'll stick to this chinese sign language: mile high pile of pictures-from-the-net... = First the 2x4, then struts tower, then... No need to me-mori-ze.
Anyways, easy to ratchet up&down, tranny is not too heavy. Do NOT place 2x4 on fenders, cut it just fittin inside. Tranny 'thickness' defines how high the car has to be...
With those quoted prices youre rich man!
Old Jul 24, 2005 | 12:41 PM
Geerhed's Avatar
As I said, I wouldn't go to Aamco. The tech at Aamco tried to rationalize his price ($2,600) by saying that, if I were to get two years' use out of the car after rebuilding the tranny, it would be like having a car payment of $100/month for just over two years. (I know: it sounded stupid to me at the time, too).
After calling a couple of shops, I decided to do this job myself precisely because I'm NOT a rich man. I'm a single dad with two teenagers to support -- not to mention a payment on my Chevy Tahoe! The Maxi is my play and commuter vehicle so I can't afford to drop a bunch of $$$ into her.
I'm looking forward to starting the tranny swap tomorrow or Tuesday.
Old Jul 25, 2005 | 01:58 AM
Phatsta's Avatar
Sorry my english translation tends to go wrong sometimes. I don't really know what it's called but here is a picture of one.
Btw, I jack the car up about... hmm... say 50 - 70cm or something like that. Basically the higher the better, to a certain point of course. It should be enough space for the tranny to come down under the car, then out of there without any problems, then you're OK.
RED92: It's not like you need to lift the tranny down, I've been alone with all my swaps. As long as you do it right there's no problem Just use an overhead crane or something like that. Like so:
Old Jul 25, 2005 | 06:26 AM
internetautomar's Avatar
mod or sell?
ring key = box end wrench
Old Jul 26, 2005 | 03:06 AM
Phatsta's Avatar
Old Aug 24, 2005 | 01:43 PM
Geerhed's Avatar
Figured I'd post the end of the story:
I got my deposit back on the junkyard tranny and got a used unit from 'Org member "UsedParts" in Portland (Maine).
I know that the torque converter was stripped on my old tranny so I decided to go with replacing the entire unit because the cost difference wasn't that much.
The car works great now, and it's wonderful to have my Max back after going without it since June 21.
Shops quoted:
Tranny: $2,600
Steering Rack: $475
New LH CV half-shaft: $200
I paid:
Used Tranny: $350
Steering Rack Bushings (the rack was fine) $7.00
Axle Seals: $7.00
CV: $60
and added:
Used Warpspeed Y-Pipe: $75.
...and did all the work myself. Not bad for a one-eyed, broken-down old piano player.
Thanks to all of you 'Org members for your great suggestions and the several write-ups here, on Phatsta's CarDomain site, and on 4DSC.com
LW
Old Aug 24, 2005 | 10:10 PM
Red89maxima's Avatar
You guys are lucky down there in the states! When I was looking for a used Auto trans for my 89 SE, I was quoted $950-$1400 for a used tranny from a autowreckers! As for the job of actually replaceing the trans it's a really easy job. It only took me 1.5hrs but I've done it a couple times so I know exaclty what I'm doing. But it's definatly a doi t yourself job. If you have the tools.
Old Aug 24, 2005 | 11:35 PM
5 ltr. beater's Avatar
Well, i've yanked out the tranny in my Maxima 3 times. The first time it took me about 12 hours to get it out and then back in. The second time it took me about 6 hours ,and then finally the 3rd time I took it back out, it took me 2 hours to take it out and 2 hours to put it back in. Keep in mind i was using a lift and my car was about 6-7 ft in the air. I honestly would never attempt to do this job on my back and as far as tools go, all you need are several 3/4 inch extensions, a socket set and a good ratchet. I didn't use much of anything else.
PM me if you have any questions.
Old Aug 24, 2005 | 11:53 PM
Wiking's Avatar
... broken-down old piano player...
Its actually a gift, just to be able to repair a broken maxchine. Only Bro Ken may understand what I mean. Fast, busy, healthy dont - yet. Happy for u!
Old Aug 25, 2005 | 01:53 AM
Phatsta's Avatar
Great stuff! It's always nice to see people succeed. Especially when they try out on something they haven't done before. Congrats from Sweden
And it's always nice to help, and to see your work being recognized like so
Happy to help man, cheers!
Old Aug 25, 2005 | 01:27 PM
jadegreenmax's Avatar
as long as we're talking about installing trannies...are there any trannies out there that are suitable as an upgrade for the 3rd gen? Like a tranny swap?
Old Aug 25, 2005 | 06:30 PM
Geerhed's Avatar
As a direct bolt-in: No.
With a little work, and a donor car, you can swap in a manual transmission.
With a lot more work, you can swap a VE auto in to a VG engine, but I don't know if there is any performance gain.
If you'd like to keep your automatic, there is a supplier who will custom build a better torque converter for you for around $350 that will make your automatic dig like a gopher.
If you need the link, let me know (it escapes me at the moment and I'm too tired to dig for it).
Old Aug 25, 2005 | 10:14 PM
bmxr152's Avatar
i was wondering if anyone had a diagram for the master cylinder thing that you have to drill thanks!
Old Aug 26, 2005 | 06:52 AM
Geerhed's Avatar
Huh?
Old Aug 26, 2005 | 07:58 AM
mod or sell?
he wnats to know where to frill the hole for the clutch master cylinder on the firewall
Old Aug 26, 2005 | 08:48 AM
I would like to swap to a Manual eventually, but for a temporary thing I think I might be interested in this link you have
Old Aug 27, 2005 | 08:10 AM
Geerhed's Avatar
The company was Edge Racing, and they custom-build the torque converters to your specs -- mild to wild.
Still looking for the link, but you can do a Google search for them, and I was told that "Andre" is the guy you have to speak to. 'Org user Aaron92SE gave me this information, and I understand he has a custom TC in his car and it's just awesome.
Best of luck.
Old Aug 31, 2005 | 08:14 PM
Aaron92SE's Avatar
NWP Engineering.com
Best of luck.
www.edgeracingconverters.com
It won't make your car an absolute beast, but it will shave .15 off your 60 foot time.... which is VERY noticable. You will notice that you will be able to spin the tires much easier than with the stock stall. And the only time you will actual track gains is if you are able to lay the extra power down. (ie, sticky tires, drag radials, slicks)
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
0m3nc0w
Sep 11, 2015 05:21 PM
pktaske
Sep 4, 2015 08:40 AM
