Replaced both LCA with poly, did the PS hose
Old Jul 25, 2005 | 06:40 AM
Jeff92se's Avatar
I'm needing a caw
and did the ball joints. That is all.
BTW. Table saw and a bench grinder is the best for shaping the big LCA bushing into shape.
Old Jul 25, 2005 | 08:19 AM
MrGone's Avatar
Old Jul 25, 2005 | 08:23 AM
Jeff92se's Avatar
I'm needing a caw
Shawnboy, take pics of your PCV filter. You said you made a breather thingie. I was looking at mine and if you want to do PCV -> hose -> filter -> hose -> intake. You would have to mount it somewhere on the firewall. You sure you weren't talking about the valve cover breather?
Old Jul 25, 2005 | 08:27 AM
MrGone's Avatar
was mounted on the back side of the intake manifold
used a mini air filter breather thing from harbor freight and some hose. Didn't cover the valve cover vent tube, but that didn't seem to ever get dirty with my car
edit: going to school
edit2: only really ran it because I wasn't looking forward to cleaning the intake manifold again.
Old Jul 25, 2005 | 08:30 AM
Jeff92se's Avatar
I'm needing a caw
How did it work? Well?
Old Jul 25, 2005 | 08:33 AM
Jeff92se's Avatar
I'm needing a caw
BTW. Thanks Internetautomar for the PS hose(and all the suspension pieces). Fit perfect.
Old Jul 25, 2005 | 08:40 AM
MrGone's Avatar
meh
worked. fun to build, didn't really accumulate much. I completely forgot about it until I was looking over everything to try and remember if I forgot anything lol.
Accidently broke it a few days ago
Old Jul 25, 2005 | 08:46 AM
Tarzan's Avatar
Harbor freight? What's that?
Old Jul 25, 2005 | 08:48 AM
MrGone's Avatar
www.harborfreight.com
tripleGmax's Avatar
how is the ride now with poly? louder or not or just better?
also i think i saw mr gone yesterday.....
Old Jul 25, 2005 | 08:49 AM
Greeny's Avatar
¯\(°_o)/¯
Its a tool company....http://www.harborfreight.com/
edit tooooo late.....
Old Jul 25, 2005 | 08:52 AM
Greeny's Avatar
¯\(°_o)/¯
Jeff did you have any problems getting the bottom of the ps hose off? Any tips if you gotem....
Im having a problem getting that part off my parts car.....
Old Jul 25, 2005 | 09:00 AM
Jeff92se's Avatar
I'm needing a caw
You know the top one was the biach. There's nothing to keep it really secure. I had to put some wood blocks inbetween the hose end and the windshield wiper motor to support it.
The bottom was was cake. Just happend to have a 3/4" drive and a 24mm(?) socket. But since the control arm was out, I might have had alot easier time with it. One reason they were both done at the same time.
Old Jul 25, 2005 | 09:01 AM
Jeff92se's Avatar
I'm needing a caw
You know, there wasn't much difference. Either in handling or ride. But it's only been one day. It has to be better though. The D-side bushing was just terrible. Very loose from beeing soaked in PS fluid for years.
Old Jul 25, 2005 | 09:26 AM
internetautomar's Avatar
mod or sell?
I have to do my bushing again :-\
she now goes clunk from time to time.
maybe I should just do the ES upgrade
but I already fixed the leak
Old Jul 25, 2005 | 09:30 AM
Jeff92se's Avatar
I'm needing a caw
Mine never went "clunk". Actually no noise. But I knew the bushing was bad. Little bits and pieces would come off every once in awhile. Brian, the poly is easy. Just burn the the old ones out/carefully slice the outer ring out. Then you have to cut the big **** bushing to shape (or use your stockers if they are new).
Old Jul 25, 2005 | 09:44 AM
mod or sell?
I saw my bushing being bad when I did the alternator.
and then I started feeling the clunk like I did when the bushing was bad the first time.
I'll probably keep my rear bushings they still looked ok to me.
Old Jul 25, 2005 | 11:59 AM
MrGone's Avatar
told ya
Old Jul 25, 2005 | 12:01 PM
Jeff92se's Avatar
I'm needing a caw
Yeah but it had to be done. Better now than when the LCA falls off at some wierd time. Plus I wanted to do the ball joints anyway.
Originally Posted by MrGone
told ya
Old Jul 25, 2005 | 12:04 PM
MrGone's Avatar
IBsqueeks
Old Jul 25, 2005 | 12:05 PM
Jeff92se's Avatar
I'm needing a caw
No squeaks.
Old Jul 25, 2005 | 12:12 PM
MrGone's Avatar
No squeaks.
not yet
Old Jul 25, 2005 | 12:13 PM
Jeff92se's Avatar
I'm needing a caw
I tried to slather that grease everywhere. How long did it take for yours to squeak? My rear poly parallel links are still quiet.
not yet
Old Jul 25, 2005 | 12:16 PM
MrGone's Avatar
few months
not bad though, only really did it going over the driveway curb. Probably just the speed + ammount of travel.
Old Jul 25, 2005 | 12:25 PM
Matt93SE's Avatar
STFU n00b!
hmm.. my poly bushings have been on for over a year now and they don't squeak
Old Jul 25, 2005 | 12:31 PM
Jeff92se's Avatar
I'm needing a caw
My rear polys have been quiet for the last month or so also. I made sure to put as much ES bushing lube as I possibly could. Man that stuff is sticky. Had to use brakeclean to get it off. Soap/water = nothing.
Old Jul 25, 2005 | 01:57 PM
MrGone's Avatar
its easy when you dont drive the car
Old Jul 25, 2005 | 10:59 PM
Jeff92se's Avatar
I'm needing a caw
Had a chance to drive it a bit harder once I knew the suspension wasn't gonna fall out. There is defintely an improvement. Just more solid. Going around the same turns at the same speed results in much firmer steering. I actually turned in too much a few times. The handling is much flatter. Not a big difference in a RSB addition or springs/shocks. But much more than a FSTB install. Of course it depends on how bad your originals were. My d-side bushings were fine. But the ball joint was a little loose. Not rattling/flopping around loose but not much effort was required to move it around. The P-side control arm bushing was terrible as mentioned. But that side's ball joint was okay. The new Moog units were 2-3x more firm and harder to move around though. But what the hell, 130k miles later, it was time regardless. Now maybe I can finally get this damned thing aligned.
If you can manage to get the LCAs off w/o too much trouble, then this is a fairly easy thing to change. There is really only a few bolts to take off. And Nissan did a good job at making these things fairly easy to remove. If you can get your hands on a spare set of LCAs and burn out/replace the bushings with poly before tearing into the car, it would make it a 1/2 day job. I waited to cut up the big rear poly bushing until right before the install. But it can be done way before, if you have a spare bushing to measure against. Again, using the table saw made the cutting to size a snap. Especially if you have the angle feature on the saw blade. A bench grinder was best to reduce the outer diameter down a bit so it fit into the bracket. Make it a tad bigger so it will fit snugly into the bracket and body. Can always shave/cut more. Not add!
Old Jul 28, 2005 | 01:20 PM
Jeff92se's Avatar
I'm needing a caw
Another update. I put the car on jacks and retighted all the bolts. Everyday I push it more. And the harder I push it, the more it impresses me how well these bushings work (or how crappy my old ones were). I'm still cutting corners a bit shallow because the steering is a tad quicker to reply.
Old Jul 28, 2005 | 04:27 PM
KLoWnPR109's Avatar
Meh, I never noticed a diff with the bushings, but then again, I drive like a little girl
Old Jul 28, 2005 | 04:29 PM
Jeff92se's Avatar
I'm needing a caw
Normal driving there is no difference. Maybe a very slight increase in noise. But then again, these RE040s are pretty loud
Old Jul 28, 2005 | 05:03 PM
tripleGmax's Avatar
Now THERE'S something to be proud of
Old Jul 28, 2005 | 05:15 PM
MrGone's Avatar
I drive like a little girl aswell... haven't mastered it like KLoWn though, I'm a works in progress.
Old Jul 29, 2005 | 06:27 AM
mod or sell?
I drive like a little girl as well.
that's because you have a little girls car
Old Jul 29, 2005 | 11:41 AM
MrGone's Avatar
yeap
5spd's = girls transmission
Old Jul 29, 2005 | 12:35 PM
mod or sell?
yeap
I was refering to your powder blue rustang
rbuswell
Nov 17, 2016 04:54 AM
kingw323
20
Oct 21, 2015 08:36 AM
schmellyfart
Sep 25, 2015 04:47 PM
maxocar
Aug 21, 2015 12:57 AM
scarletsosa
Aug 17, 2015 09:09 PM
