noise from front of car
Old Jul 30, 2005 | 02:39 PM
sapp99's Avatar
recently i have been noticing a deep whup whup whup sound coming from the front of the car when the car is in motion. I was wondering if it could be alignment issue or off balance tires or what? my steering wheel is not centered that why i guessed maybe an alignment issue. what are your thoughts?
Old Jul 30, 2005 | 06:35 PM
sapp99's Avatar
any ideas?
Old Jul 30, 2005 | 06:54 PM
doomtoo's Avatar
Originally Posted by sapp99
any ideas?
It might be a tire seperating - u could try to exchange front tires w back to see if it might be going-
Old Jul 30, 2005 | 07:08 PM
max723's Avatar
sometimes i get a clunk sound when i turn my wheel all the way. is this similar? sorry but dont know what it is
Old Jul 30, 2005 | 10:55 PM
Drivin Maxima's Avatar
well it could be belt separation on the tire, or an allignment issue......
First things first take a look at the tires and see if theres any odd wear that would indicate an allignment issue.
second, if there is nothing that appears to be wrong with the tires then check to see if the sound goea away or changes when making a turn.....if so then wheel bearing is a poss.
Good luck
Old Aug 1, 2005 | 01:44 AM
Wiking's Avatar
- I suppose not tire related. All Nissans I have got, intermittently do this. If its constant (and not in the end), must do a checkup.
- sapp: Tire separation is a death serious problem. If you have those crap re-threaded tires, replace without asking. If u cannot afford, definitely walk! The sound description above fits this problem, dont know any other issues than tires which could make such. If u want to be sure, swap noisy tire to rear and listen; u might survive if it explodes in the rear...
Old Aug 1, 2005 | 02:29 AM
Greeny's Avatar
¯\(°_o)/¯
That sound is probably your driveshafts needing replacement.
Buy them from internetautomart.....He's needs monies...
Old Aug 1, 2005 | 05:14 AM
Mizeree_X's Avatar
Getting back to his roots
Does it sound like a helicopter? If so, make sure your lug nuts are tight!!
Old Aug 1, 2005 | 05:33 AM
Wiking's Avatar
wuh wuh
Old Aug 1, 2005 | 06:31 AM
Will's Avatar
All possible suggestions above, but if it only happens when you hit 35 mph and up, it might be a wheel bearing.
Start simple, and inspect the tire closely. I've had these types of noises before where it turned out to be either a nail or good-sized pebbles embedded into the tire near the shoulder, and so when it rolls, it makes noises when it hits the pavement. Good luck.
Old Aug 1, 2005 | 06:45 AM
Maxima Man's Avatar
I have a noise in the engine compartment...
It only makes this clunk clunk sound with some viberations when I first start the car ( like when the starter is engadged and the motor is trying to start to run under its own power)
The car runs great other than that but it is kind of puzzling!
Can anyone tell me if this is normal or if not what is wrong thanks!
Old Aug 1, 2005 | 06:52 AM
Greeny's Avatar
¯\(°_o)/¯
VE or VG motor?
Old Aug 1, 2005 | 07:50 AM
Maxima Man's Avatar
Vg motor ........................
Old Aug 1, 2005 | 08:13 AM
Jeff92se's Avatar
I'm needing a caw
Motor mount?
Old Aug 1, 2005 | 08:22 AM
Maxima Man's Avatar
I know the truth hurts but ......i was hoping it wasnt that !!
Have you had an experince with a broken motor mount?
How many mounts are there on the motor ?
Are they hard to fix? Are they expensive to buy?
Where are the motor mounts located?
Sorry for all the q's but any answers would be great!
Thanks Jeff!
Old Aug 1, 2005 | 08:24 AM
tripleGmax's Avatar
maxima man, you win most questions asked in one post!!
no
get new poly ones, someone on here makes them
uhh the motor mounts to them
Old Aug 1, 2005 | 08:29 AM
Maxima Man's Avatar
Does it damage the motor to run and drive it with a motor mount broken!
(If it does just lie and say it dossent hurt it any) Just kidding!
How much do motor mounts cost? Are they hard to fix?
Is it most likly just one mount broken or both.......
Thanks for all your quick replies! Thanks tripleGmax and Jeff!
Old Aug 1, 2005 | 08:42 AM
Greeny's Avatar
¯\(°_o)/¯
Driving around with a broken motor mount puts extra wear on the other one's that are not broken, not to mention stress on the exhaust system with all the extra movement.
Old Aug 1, 2005 | 08:53 AM
Maxima Man's Avatar
I just want to check that it is broken!....
Where is the motor mount located on the motor?
If anyone has previously had this problem tell me the simptoms of this please to verify that i do have a broken motor mount!
Thanks!
Old Aug 1, 2005 | 08:57 AM
Jeff92se's Avatar
I'm needing a caw
While you are at it, read the whole manual.
http://www1.autozone.com/servlet/UiB...Parameters=004
Old Aug 1, 2005 | 08:58 AM
Greeny's Avatar
¯\(°_o)/¯
Thanks!
Try having a helper start the engine a few times while you are under the hood looking and listening where the clunk is coming from....
Old Aug 1, 2005 | 09:01 AM
Greeny's Avatar
¯\(°_o)/¯
Then 20 questions time would be over Jeff.....
Old Aug 1, 2005 | 09:05 AM
Maxima Man's Avatar
If i have my engine runing and i have someone rev the engine will the motor move alot ?
I am just trying to find out all the simptoms to check to see if i do indeed have a broken motor mont!
Old Aug 1, 2005 | 09:08 AM
Greeny's Avatar
¯\(°_o)/¯
If your hearing the clunking at startup only then thats when you need to be paying attention under the hood with a helper starting it and stoping it over and over again.....
Old Aug 1, 2005 | 09:09 AM
Maxima Man's Avatar
I am going to check my motor out this afternoon with a buddy of mine!
I am 17 and don't need to drive it, so i will baby the motor even more than usual until i can fix the motor mount!
Old Aug 1, 2005 | 09:13 AM
Maxima Man's Avatar
Are there any indications that you can feel while driving the car down the road that would tell you that the engine mount is broken?
Old Aug 1, 2005 | 09:22 AM
tripleGmax's Avatar
how are you going to fix it when you dont know what a motor mount looks like
also if you start the car and pop the hood, give it some gas and see if the engine moves too much, thats a good indicator its broke. ive seen Alex_v's wrecked maxima and his broken mounts were very easy to see. but that was probably because he ran head first into a dump truck
Old Aug 1, 2005 | 09:28 AM
Maxima Man's Avatar
what is to much...? An inch ---- foot ( just kidding)
How much should the motor move without broken motor mounts?
Why do u say that i dont know what they look like ( i have seen them on my car before but didn't connect them to being the motor mount in my mind) ( btw there is a pic a couple of posts up)
Hondarydr
Dec 30, 2024 06:15 PM
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
