Stubborn Exhaust Manifold Stud...pic
Old 08-06-2005 | 07:04 PM
  #41
mattcomet82's Avatar
they refuse to look at the manifold? when i went to my local muffler shop 2 weeks ago, they put the car on a lift and got underneath it to check the manifolds for leaks. if dudes refuse to check the manifolds, take it to another shop. try something local, not a midas or similar chain.
Old 08-07-2005 | 06:09 AM
  #42
mv420xx's Avatar
just changed my exhaust manifolds, 1200$ later...
Old 08-07-2005 | 04:49 PM
  #43
internetautomar's Avatar
mod or sell?
Originally Posted by mattcomet82
you wouldn't happen to have these available would you?
nope, just stock ones
Old 08-07-2005 | 09:21 PM
  #44
maximutt's Avatar
Are there any write ups any where on how to replace the studs?
Old 08-07-2005 | 11:11 PM
  #45
Phatsta's Avatar
Originally Posted by CandiMan
Spray with penetrating oil and let sit over night. Use the propane torch to heat the head. I think the head would have to get cherry red before warping becomes an issue, use your judgement.
Use a stub remover like this one
A socket type like this one would be a lot better
Or the budget version
Old 08-07-2005 | 11:27 PM
  #46
CandiMan's Avatar
Say Candyman 5 times
The double nut budget version is definately a tried and proven method for removing and installing studs, but when you have a stud in the condition like his the budget version isn't an option.
Old 08-08-2005 | 06:17 AM
  #47
Tarzan's Avatar
If welded to the end of stud, than yes. If welded at the block than it is no different than expensive stud extractor.
Originally Posted by Jeff92se
That's a good way to break the stud too. Use the tool(s) mentioned above. It's what I've used. It grips the stud nearer the base.
Old 08-09-2005 | 12:25 PM
  #48
aminus21's Avatar
Got it out!!!
Old 08-09-2005 | 01:15 PM
  #49
Geerhed's Avatar
Moved on to BMW's :(
VICTORY!
Good job, Animus.
Old 08-09-2005 | 08:23 PM
  #50
CandiMan's Avatar
Originally Posted by aminus21
Got it out!!!
What's your secret? How did you finally get it out? After all this you can't leave us hanging. The hole that's in the stud, does it have anything to do with how you got it out?
Old 08-09-2005 | 10:42 PM
  #51
aminus21's Avatar
Of course it does. I drilled through the stud vertically, and stuck an allen wrench in there, then turned the allen wrench. I used lots of PB Blaster on the part where the stud meets the head.
Thanks for all the help guys..
Old 08-09-2005 | 11:07 PM
  #52
CandiMan's Avatar
Of course it does. I drilled through the stud vertically, and stuck an allen wrench in there, then turned the allen wrench. I used lots of PB Blaster on the part where the stud meets the head. Thanks for all the help guys..
Props for thinking outside the box, you must have a pretty steady hand to drill a hole dead center in the stud. The solution was out of the ordinary, but whatever gets the job done.
Old 08-10-2005 | 08:05 AM
  #53
aminus21's Avatar
If that wasnt gonna work, I was gonna chase down a snap-on truck and buy the tool you recomennded. I checked 2 hardware stores, and they didnt have it. I also checked pep boys too.
Old 08-10-2005 | 08:17 AM
  #54
mod or sell?
you mean Pep "everything but actual auto parts" Boys
Old 08-10-2005 | 01:24 PM
  #55
aminus21's Avatar
ya heard.. they now even sell school supplies, like backpacks, etc..... how lame
aw11power
10-10-2021 04:57 AM
JonBlz
10-05-2015 06:02 PM
Justin Kroll
10-01-2015 07:03 PM
dshinn
09-26-2015 08:07 PM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: Stubborn Exhaust Manifold Stud...pic
