Sputtering problem
Old Oct 11, 2000 | 10:13 AM
Hey guys....Unfortunately I do not own a Maxima. BUT--my Boss at work has got a 90 V6 Maxima (auto) and has had a sputtering problem for a little while with it. I thought I'd do him a favor and check with the pro's on some Tech Boards and see what you guys think.
The car sputters, during initial start up, to the point of dying. But...after about a minute of chugging ad chugging it will regain a stable idle and drive perfectly fine. I am thinking it's an O2 sensor, but since I know nothing about Maximas I need to know how many O2 sensors the 3rd Gen's have?
I can't see this problem being anything other than spark or fuel. Maybe plugs? The really puzzling thing is that there are no check engine lights.
Got any ideas? Thanks guys.
Micah
P.S. The car has 140K miles on the stock longblock.
Old Oct 11, 2000 | 10:31 AM
Matt93SE's Avatar
STFU n00b!
The sputtering is common in this engine. What I'd suggest is that he turn the key to the "on" position and wait a few seconds before actually starting the car. this will let the fuel pump "prime" the lines, and it should help it start quicker.
I've never had the car sputter and bog that long- mine is usually about 10-15 seconds. usually if I just let the car idle for about 15-20 seconds before putting it in gear, it's fine. if I stick it in gear as soon as I start, it will die while I'm backing out of my driveway (downhill)..
Another common thing is that the plug wires develop tiny cracks and someone said they opened the hood in the dark and could actually see the ignition spark arcing from the wires to the block when the engine "stumbled". He replaced his plug wires and said it's been fine ever since.
Hope that helps!
Old Oct 11, 2000 | 10:37 AM
DanNY's Avatar
Ad·min·is·tra·tor
Micah
also keep in mind the O2 sensor does not come into play until the exhaust is hot enough.
i would recommend a full tune up w/ Nissan original parts. replace the rotor and cap..also check the spark plug wires.
Dan
Old Oct 11, 2000 | 10:42 AM
Greyboy
I have a 93 GXE with the VG
Does this car have a rotor and distributor cap? I always thought it had electronic ignition! Hmmmmmm...
Old Oct 11, 2000 | 12:41 PM
brubenstein's Avatar
My wife's 88 Max (same engine) was doing the same thing. I changed the plugs, cap and rotor and all the problems went away.
Old Oct 11, 2000 | 12:48 PM
chris92gxe's Avatar
If you want to change the O2 sensor then the car has one. It is located right before the cat under the car. They are pretty easy to change as long as you get another O2 sensor with the pug in harness. The cheaper one's that you splice I would not recommend. This may not be your problem but you could check to see if it needs replacement anyway. Ussually if it is the problem you will sputter while driving noe just when the car first starts.
92GXE, touring wing, 18” racing wheels, Port&Polished intake, custom intake, custom yellow interior, racing seats, back seats taken out and replaced with subs and amps, NOS kit, Suspension tech. Lowering springs, custom grille, soon to be custom painted and have the whole engine rebuilt for big shot NOS and custom SC and tranny converted to 5-speed.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
homewrecker
Sep 24, 2015 07:01 PM
