Hesitation & surging - then CEL came on
Old 08-18-2005, 10:07 AM
Pauls 98 SE's Avatar
At idle the engine is smooth at about 800 rpm, with or without AC. When give it gas to pull away from stop, engine bogs down and hesitates till about 1200 rpm then surges to about 1800 – 2000 rpm. Acceleration is not smooth and surges as long as accelerating. Also acceleration is slower than normal all the way through 60 -70 mph (probably higher but have not tried). This is being easy on gas pedal. I can hold a steady speed on flat road with no surging. Slightest push on pedal and engine bogs, then transmission kicks out of OD and I must push harder and eventually cause a downshift to get any acceleration or to maintain speed on incline. If pushing hard on pedal, the surging is much more noticeable.
Problem started a couple of days ago and is continually getting worse until today the CEL came on while accelerating. Flashes while accelerating and solid when holding speed and goes off when at idle. Checked ECU for codes a couple of times now and LED is flashing 55.
Recent repairs: new fuel pump, new O2 sensor, new MAF sensor
As always, thanks for the input and advice.
Paul
Pauls 98 SE is offline
Old 08-18-2005, 10:31 AM
max723's Avatar
im not 100% sure but check to make sure you dont have any air leaks/loose hoses in the engine such as vacuum hoses
max723 is offline
Old 08-18-2005, 11:06 AM
MAXI's Avatar
i want to say, O2 sensor. if you're interested in checking this......disconnect the O2, start and drive the car, see if the bogging disappears.
MAXI is offline
Old 08-18-2005, 11:36 AM
¯\(°_o)/¯
Greeny's Avatar
Check ALL vacuum hoses under hood for leaks. windex is good to squirt on them to check for leaks And look for disconnected electrical connections..
Greeny is offline
Old 08-18-2005, 11:53 AM
Way out West
Cliff Clavin's Avatar
This is kind of a strange one.
Without any codes, it's kind of tricky. Mine acted similar when my coolant temp sensor went out, but it displayed a code for it. My idle also surged at the same time, but my IACV was full of crap.
I suppose you could check the coil packs. They seem to be a common problem in the areas of bogging down and stalling.
Cliff Clavin is offline
Old 08-23-2005, 04:57 AM
I have been checking electrical connections and vacuum lines, all seem to be good.
Car has started to die if I sit idle too long, like at a long stop light. The sluggishness and surging has become BAD....
Is this the behavior of a failed IACV? The FSM mentions this alot as I read through the problem diagnosis section.
Thanks -- I am in desperate need of advice.
Old 08-23-2005, 05:10 AM
¯\(°_o)/¯
Greeny's Avatar
If your problem is only at idle then I would suspect the iacv being the problem. I have a good used for sale if you find it to be your problem...
Greeny is offline
jmlee44
10-02-2022 02:13 PM
JoshG
51
09-21-2015 10:41 PM
RWCreative
09-21-2015 11:01 AM
jchronis2552
09-21-2015 05:52 AM
trungg86
09-04-2015 04:58 AM
Quick Reply: Hesitation & surging - then CEL came on
