Horn Not working
Old Aug 20, 2005 | 07:50 PM
Trevmister1610's Avatar
Horn Not working
yesterday i got cut off and nearly rear ended the guy so i went to slam my horn and nothin happened, later that night i went home to see if i could figure out whats wrong, when i press the horn i can hear the relay switching (at least thats what i think it is) but no horn, but if i keep pushing it then every once in awhile the horn will make a faint quick sound. Before i buy a new horn i just wanted to make sure that, this will correct my problem?
Old Aug 20, 2005 | 08:28 PM
kcidmil's Avatar
The easiest way to check is take a jumper wire from the positive terminal battery to the power terminal of the horn. If it blasts, you have a loose connection somewhere. If it does the little quick sound still, the horn is shot.
Old Aug 21, 2005 | 09:42 AM
Maxima Man's Avatar
I had my horn stop once and the cruise control went also i took it to the Stealership and they Fixed it !!
It was a problem with the power spring that supplies power to the steering wheel !
It is a special spring ( have to buy from stealership)
Old Aug 21, 2005 | 10:07 AM
kcidmil's Avatar
His won't be the power RING. When he hits the horn button, the relay clicks. Which means his button is doing what it's supposed to do, and grounding out the relay. This suggests one of the following
-Bad connection off the relay to the horn
-Bad power terminal connection at the horn
-The horn is shot
-Bad grounding for the horn
Old Aug 21, 2005 | 10:14 AM
Greeny's Avatar
¯\(°_o)/¯
Does your middle finger still work???
Old Aug 21, 2005 | 10:20 AM
kcidmil's Avatar
I agree, this natural body reaction gets the point across much better than any horn. Though it does lack the loudness needed to draw the attention of the mindless moron.
Old Aug 21, 2005 | 10:25 AM
Red89maxima's Avatar
My friend had this same problem, but his was caused by a short in his alarm. Whenever he pressed on the horn it would draw power from the horn through the alarm relay and the clicking sound was his alarm relay. Do you have an alarm on the car? If you do and it does not travel through your horn and has it's own siren then you have nothing to think about, just disregard this msg!
Old Aug 21, 2005 | 10:27 AM
kcidmil's Avatar
Our cars came with an alarm on it. Though since he does seem to get a "squeek" out of it, I think it's horn itself that has finally shot.
Old Aug 21, 2005 | 10:28 AM
Wiking's Avatar
My horns work day and night. Roof upholstery torn off...
Old Aug 21, 2005 | 11:03 AM
Greeny's Avatar
¯\(°_o)/¯
If you have a cai then just revv it up before deployment of finger....That will get his attn:
Old Aug 21, 2005 | 11:24 AM
lol i do have a cai and a perfectly good working middle finger, but the effect of all three would be much nicer, thanks for the advice, anyone know how much a new horn is gonna cost me?
i just thought of this, could i just go to a junk yard and pull it off of any car?
Old Aug 21, 2005 | 12:01 PM
kcidmil's Avatar
yep
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
