tranny really getting bad
Old Sep 8, 2005 | 06:06 PM
vansskaterfreek's Avatar
well just about every time it is cold my first gear slips going into second..this is what it does......when shifting fron first to second, it takes asecopnd or two, in the meantime i can floor it and rev it really high and the RPM's will just rise, kinda like it is in neutral, but it doesnt slam into 2nd........only when cold at a stop light the car starts bucking kinda like it was a stick and i didnt push the clutch in at a stop light. and almost stalls, one day it did stall. so i am gonna start looking at the 5spd conversion........what exactly would i need from a 5 spd car. master cylinder, clutch pdal, ETC. i need EVERYTHING for a stick
Old Sep 8, 2005 | 06:19 PM
Greeny's Avatar
¯\(°_o)/¯
Look through the for sale forum for a donor car for the swap or start a wtb thread in there.....
Old Sep 8, 2005 | 07:06 PM
Scope's Avatar
Im izz sexay
Best bet is to find a donor car or see if any local junkyards have a 5-speed maxima and buy it from them.
Old Sep 8, 2005 | 07:19 PM
i have a VG, would a VE 5spd work without modification??? probably not, but it dont hurt to ask
all the maximas in the junk yard have over 150k.....mot have 180k or more, well that is just the one place
there was one VE, but the motor was all torn up. i can also get the tranny from a 1989-1994 SE or GXE right, so any 3rd gen tranny will fit in my 1991 SE?
Old Sep 8, 2005 | 07:34 PM
Alex_V
yea, and if you get a VE 5speed, its even better as it has the VSLD. you just need the axles and hub carreries as well.
~Alex
Old Sep 8, 2005 | 07:47 PM
Scope's Avatar
Im izz sexay
I have learned one thing from my max before I sent it off to the junkyard. Mileage means nothing if the car was well taken car of. My engine had 241k and never gave me one issue. My tranny well I went through three. One of them had 87k miles and I even saw the car being pulled in by a wrecker as it was rear ended badly. And I checked the mileage. That tranny lasted me 10k miles. I dogged it. But it was also an auto.
All 3rd gens have the same bolt patterns meaning they are all compatible. VE's you have to replace the hubs and axels as the VG's are too smal.
Old Sep 8, 2005 | 11:18 PM
Wiking's Avatar
...when cold at a stop light the car starts bucking ...
What would another tranny help in tHere?
You will return to TPS, why not start from it. You will return to oxidized connections, why not start from it?
Old Sep 9, 2005 | 12:03 AM
Phatsta's Avatar
again:
http://www.cardomain.com/ride/749143/2
how to take the auto trans out
http://www.cardomain.com/ride/749143/3
what you need from the manual donor car and how to bolt it on
Old Sep 11, 2005 | 12:19 PM
i dont understand, LOL and yes i looked at the sticky's about the manual swap.....i think i am up to it. its just gonna be fun with me under the car because there is barely enough room for me to get under the way they are sitting up on the rims at the junk yard
Old Sep 11, 2005 | 12:39 PM
wolfpack_5150's Avatar
Apple Pie Monster
Wiking is trying to point you to check your Throttle Positioning Sensor, and connections. Hes saying check these first, as he believes they are causing some problems now. Otherwise you may throw in another tranny, have new issues stemming from the new trannys own gremlins and also may still have your stalling issue to figure out. Check your TPS and connections, so you can rule those out. Then throw in a new tranny and work out any gremlins with it. 1 thing at a time.
Old Sep 11, 2005 | 04:34 PM
where is the throttle position sensor located on my VG????
Old Sep 11, 2005 | 04:39 PM
Greeny's Avatar
¯\(°_o)/¯
On the side of the throttle body...A black square box.....with wires going to it...
Old Sep 11, 2005 | 05:06 PM
k thanks........im searching for people with parts for a 5 spd swap now also.....the tranny is slilpping in 1st gear, so im swapping in a 5 spd.....i just need cheap working parts
Old Sep 11, 2005 | 05:19 PM
Greeny's Avatar
¯\(°_o)/¯
I strongly suggest getting a complete donor car......this will make it ten times easier.....
Old Sep 11, 2005 | 06:51 PM
so if i go to a junk yard, will they sell me the whole car, or give me the title, take parts off, then give car back? ill ask tomorow what they can do for me... i just need an accurate and COMPLETE list of what i need
Old Sep 11, 2005 | 08:25 PM
Greeny's Avatar
¯\(°_o)/¯
The junkyard is not the place to buy a parts car.... if you know i mean....Best place to buy is a from a private owner....
Old Sep 12, 2005 | 12:28 AM
Wiking's Avatar
Do u ever read what is written? If u have electronics problem, changing gas tank will never help. Neither swapping tires, tranny, engine, lamps etcetc...
This time for TPS click on http://www.cardomain.com/ride/748507/6
For other electronics issues, read all pages:
http://www.cardomain.com/ride/748507/1
chisam14
Nov 6, 2018 08:56 PM
fx4five
Oct 18, 2015 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
Andy29
Sep 29, 2015 05:32 AM
